Projector location
Old 03-09-2003, 12:05 PM   #1
relevant
Posts: n/a
Projector location
I have a squareish room which is 18 feet (5.5 metres) long and about 12 feet high. I would like to have a screen which is about 5 feet wide, to be viewed from about 10 feet away.
Ideally, the projector would be on a stand against the rear wall of the room, next to the DVD and audio equipment. Would the long distance (18ft from the projector to a 5ft wide screen) be a problem? Could this be solved with a suitable lens without compromising quality? I haven't decided on which projector to go for yet, so any views about which one would be good choice for viewing at this sort of distance would be welcome.
Sorry if this is a FAQ and I should have looked further before asking it.
Old 03-09-2003, 12:31 PM   #2
Anders_UK
Posts: n/a
You are looking at a throw ratio of close to 3.7:1. Which is a big ask for a modern small projector, as most of these range from 1.3-2.5:1.
Either look at mounting it further into your room, another lens source, or try and find a PJ with this ratio lens as an option.
Better still go for a bigger screen, but resolution will suffer slighlty
Old 03-09-2003, 12:34 PM   #3
Senior Moderator
LV426's Avatar
42,412, Level: 50
Points: 42,412, Level: 50 Points: 42,412, Level: 50 Points: 42,412, Level: 50
Activity: 31.8%
Activity: 31.8% Activity: 31.8% Activity: 31.8%
Thanks: Gave 1,530, Got 1,592
Absolutely, not. But subjectively, maybe.
Old 03-09-2003, 12:53 PM   #4
6,657, Level: 19
Points: 6,657, Level: 19 Points: 6,657, Level: 19 Points: 6,657, Level: 19
perhaps you'd be better off going for a plasma if you want a smaller screen - any particular reason for this size or are you worried about quality at this viewing distance (screendoor, artifacts, pixelisation).
My room sounds similar to yours and I have a Panny 300 which has a quite short throw. I have a 6'8" wide screen and sit about 11 feet away. This seemed to me to be about the right size screen for that viewing distance as a compromise between the wow factor of having a big screen and decent picture quality. If I had a bigger room then I'd use a bigger screen but also sit further away!
Old 03-09-2003, 1:40 PM   #5
Kramer
Posts: n/a
Impossible to project such a small image from such distance, unless you want to spend half as much as the PJ for an adittional long throw lens. Even then, I think it would be a no no.
Why not a bigger screen? The room certainly seems big enough to warrant a 92" or even 106" screen.
Longest throw PJ currently available (well, one of) is the HS10. Produces a nice picture (110") from about 13/14'. I sit approx 11' from screen.
Old 03-09-2003, 5:51 PM   #6
Anders_UK
Posts: n/a
Nigel, the bigger you go the worse resolution you get!!
Its not just the number of pixels in an image that makes up the resolution figure!
Old 03-09-2003, 8:02 PM   #7
17,649, Level: 32
Points: 17,649, Level: 32 Points: 17,649, Level: 32 Points: 17,649, Level: 32
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 128, Got 182
Surely the resolution stays the same no matter what the distance but it is the image quality which changes (better or worse depending on distance). Surely an 800x600 resolution image is 800x600 no matter how big or small the actual image is? No?
Old 04-09-2003, 5:16 AM   #8
relevant
Posts: n/a
Thanks very much for responses and advice.
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
2 prices from
 £149.95 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
7 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 12th at 1:30pm. Prices include delivery.
