New Mitsubishi HC5500 no horizontal lens shift!
Old 15-01-2009, 4:58 PM   #1
pure_geordie's Avatar
6,626, Level: 19
Points: 6,626, Level: 19 Points: 6,626, Level: 19 Points: 6,626, Level: 19
Thanks: Gave 20, Got 33
Exclamation New Mitsubishi HC5500 no horizontal lens shift!
Hello, I'm about to take the plunge and buy a new projector. The Mitsubishi HC5500 and just found out that it doesn't do horizontal lens shift.
Does this mean my cealing mount will have to be in the perfect position on my ceiling (in the middle) and slightly offset as the lens on this projector is not exactly in the middle?
It does do vertical lens shift but isn't it more obvious to have horizontal instead as most ceiling mount go up and down but don't go side to side.
Thanks.
Old 15-01-2009, 5:37 PM   #2
Assured Advertiser
Liam @ Prog AV's Avatar
27,694, Level: 40
Points: 27,694, Level: 40 Points: 27,694, Level: 40 Points: 27,694, Level: 40
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 6, Got 803
Re: New Mitsubishi HC5500 no horizontal lens shift!
You need vertical lens shift because your screen position up and down the wall in relation to the lens will be different. If you just screw the projector onto the ceiling and hope you might find that it needs the screen to be right up too how, or conversely touching the ground. With lens shift this gives you bigger range.
Horizontal lens shift is just where you haven't been able to position the mount/lens central to the screen position. This isn't exactly difficult to do, the old school method is still the best - use two identical length pieces of string and run from the top left and right corners of the screen. Where the strings meet is where the lens wants to be.
How much does a cockney pay for shampoo? Pantene
call me: 01892 860801 / e-mail me: liam@progressive-av.com / twitter me: @ProgressiveAV
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
jArgHA (26-01-2009)
Old 10-02-2009, 5:58 PM   #3
Thanks: Gave 28, Got 6
As it has no horizontal shift... If the ceiling mount can turn horizontally, will that be ok? Or will the image be out no matter what I do with keystone etc?
My ceiling mount is off centre due to where the beams are...
TheToe
Old 10-02-2009, 10:01 PM   #4
3,633, Level: 14
Points: 3,633, Level: 14 Points: 3,633, Level: 14 Points: 3,633, Level: 14
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 5, Got 21
TheToe
It'll be out no matter what you do if its off center. You won't get it to focus across the width of the screen, and keystones always cause a loss of quality. I'm getting the same pj and be careful as it has quite a limited vertical lens shift as well. You may find the pj has to be quite low, a good distance from the ceiling.
TheToe (11-02-2009)
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.47 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
2 prices from
 £149.95 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
3 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
7 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 13th at 4:30pm. Prices include delivery.
