Side Shot Technology
Old 01-07-2003, 1:59 PM   #1
WBC WBC is offline
8,304, Level: 21
Points: 8,304, Level: 21 Points: 8,304, Level: 21 Points: 8,304, Level: 21
Thanks: Gave 9, Got 2
Question Side Shot Technology
Guys,
I'm gagging to buy a projector but I know they are just NOT wife friendly!!!
I've seen that Sony do two models that use side shot technology, VPL-HS2 & VPL-HS10. Are they any good????
I understand key correction has an impact on picture quality but how much??? I'm sure I'd be allowed a projector if it could stand on a unit at the side of the room. Do any other manufacturers offer anything similar? Would the Sony's be a good bet or should I stick to my 32" TV
Thanks People
Stace
Old 01-07-2003, 2:05 PM   #2
nathan_silly
Posts: n/a
Yee really divvent want te use the off-side keystone correction- you'll loose resolution. Playce the projector in the middle (horizontally) te the screen, an either above below or in the middle o the screen (vertically)
Ah thowt yee were a lass ?
Old 01-07-2003, 2:10 PM   #3
WBC WBC is offline
8,304, Level: 21
Nathan,
Never make an assessment by a persons name I know men called Kelly and Tracey
What about my Avatar, I hope people don't think I like knobs !!
Anyways back to the point, I'm not allowed one in the middle of the room, my wifes too house proud.
Will the keystone correction make that much difference??
Stace (The Man)
Old 01-07-2003, 4:18 PM   #4
Chris Frost's Avatar
9,048, Level: 22
Points: 9,048, Level: 22 Points: 9,048, Level: 22 Points: 9,048, Level: 22
Thanks: Gave 47, Got 115
Stace, there's more than one way to skin a cat.
A projector doesn't have to live in the centre of your room. The thing that determines where it can be placed is the lens. Some manufacturers use short throw lenses (big picture, short distance screen to projector) whilst others use longer lenses (same size picture, longer projection distance).
A projector with a longer throw lens could mean the unit is mounted at the back of your room. The result is more like a cinema, the projector shining over your heads to the screen.
Check out projectors with longer throw lenses. You may find something that fits your budget and your room.
Good luck
Old 01-07-2003, 5:27 PM   #5
Illustrious Member
48,563, Level: 53
Points: 48,563, Level: 53 Points: 48,563, Level: 53 Points: 48,563, Level: 53
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 884, Got 1,284
side shot takes it's toll on piccy quality but you can pull the usual one of getting a HS10 (lovely) and running with side shot for a month and then demo it in the middle of the room
Old 02-07-2003, 10:35 AM   #6
MrSafety
Posts: n/a
... and bear in mind that the picture quality that is acceptable to you isn't necessarily the PQ acceptable to the next man/woman.
My twopence: I have an HS10 which is currently sat on a coffee table at the side of the room on maximum sideshot setting and I am more than happy with it. When I sort out a ceiling mount it will be moved to the centre of the room but I don't really expect to notice any difference in picture quality and, given the quality I already enjoy, don't much care!
If you're going from a 32" telly to an HS10 you'll be blown away regardless of what you project it onto and where you project it from.
Old 02-07-2003, 6:07 PM   #7
Illustrious Member
48,563, Level: 53
Activity: 0.8%
Originally posted by MrSafety
... but I don't really expect to notice any difference in picture quality and, given the quality I already enjoy, don't much care!
I give you a month and you will never go back....
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
5 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
 Updated February 10th at 10:30am. Prices include delivery.
