I've been browsing these forums for a while now and have found them very usefull indeed, but i now have a problem which i can seem to find a straight answer for....
Today i was given a proxima 6810 projector, and after setting it up i find that the screen has lots of blueish purple dots on it.
Now i looked on the forums and people were describing similar problems and saying "here is a picture of it so you can see what i mean" but i could see no picture so cant be sure if its the same problem i'm having!
So i thought i would join up and see if anyone here could help me out!?
anyway here is a picture of the projection so you can understand my problem a little better...hopefully.
incase that didn't work here is a direct link to the photo...
http://i193.photobucket.com/albums/z...n/DSCN0059.jpg
any help would be would be brilliant and if there is anything else you need me to tell you, just ask!
Thanks in advance
Ben
