Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD200X
Optoma Pico
Epson EMP-TW700
Acer X110
Panasonic PT-AE3000
Optoma ES522
 More...Prices updated November 22nd at 4:30am and include delivery.
Optama DS306,Infocus N1,TOSHIBA TDP S8,VIEWSONIC PJ513D fatboyslim1992 Projectors 0 11-06-2008 3:50 PM
Optoma HD80 - Overkill or good choice for my room! DPWatts Projectors 11 18-01-2008 2:26 PM
Optoma DS306+ poisondwarf Projectors 3 25-12-2007 9:31 AM
Stretch my budget to purchase Sanyo PLV-Z5 or Optoma HD70 over the Optoma HD720x? Sirion Projectors 5 29-11-2007 1:45 PM
New Room - New Kit inc. Optoma HD72i/Denon 2807 demon-jules Projectors 4 06-09-2006 10:34 AM
Old 11-06-2008, 9:59 AM   #1 (permalink)
Smile Optoma ds306 help with room
Can anyone help me??
we are havin an extension on our house and im gettin a new bedroom ? from where i want to project on the wall to where the projector is going to be placed is 10ft.
i need help on choosing a projector with a budget of about £250 maybe £300. I also want the projection to be around 6ft diaganally across.
Thanks In Advances!
fatboyslim1992
fatboyslim1992 is offline   Reply With Quote
Old 11-06-2008, 10:23 AM   #2 (permalink)
Thanks: Gave 42, Got 44
Re: New Room And New Project Im A Noob
Optoma 700X? £395 on Dixons but with discounts and Quidco you could probably bring it down to about £350-370. Bit over your budget but worth considering the extra stretch.
ScarySquirrel is offline   Reply With Quote
Old 11-06-2008, 10:42 AM   #3 (permalink)
yes out of my depth slightly... isnt there anything for £300? its going to have my xbox 360 and sky hooked up ?
onto a white wall with grey surrounding walls??
any take on that?
Old 11-06-2008, 11:10 AM   #4 (permalink)
Thanks: Gave 117, Got 257
any take on that?
Really good HD-Ready pj's start at about £400, such as the model mentioned above and the HD65. You won't get anything decent for £300ish, just a 4:3 (not widescreen) multimedia model, not really suitable for Xbox 360 or Sky.
You could check the classifieds as these sometimes appear in there?
JVC DLA-HD350, Pioneer PDP-4280, 60GB PS3 (UK), Humax 9200, Humax Foxsat, Denon 2307, Mordaunt Short 309i sub, 905i centre, 2 x 906i front floorstanders, 2 x 904i rears, 2 x 302 rears
stuartbrown21 is offline   Reply With Quote
Old 11-06-2008, 11:23 AM   #5 (permalink)
okay.. what do people you people think of the ds306???
is this suitable for xbox 360 and sky?
thanks
Old 11-06-2008, 11:27 AM   #6 (permalink)
Thanks: Gave 75, Got 78
Definitely keep an eye out in the classifieds, picked up my HD65 for £300 and have been very happy with it.
CallMeSteve is offline   Reply With Quote
Old 11-06-2008, 11:29 AM   #7 (permalink)
are the infocus n1 gaming projectors a waste of tyme ?
Old 11-06-2008, 4:32 PM   #8 (permalink)
Thanks: Gave 3, Got 67
If your top budget is top at £300 do whatever you can to extend it so that you can afford a Optoma Hd70 or Hd65....
TRUST ME, do not bother getting a projector that is not Hd Ready in terms of its native display is not true 720p,,,, it will just look awful, I've been there and done it, there really is no point in having a big screen and the image blurry all because a it isn't a HD projector....
The xbox 360 would just be rubbish, its a HD console, so give it a HD display, it will look amazing, for £350-£400 the quality of the projected image is fantastic value for money...
I bought a typical cheap projector first, it was ok to begin with, but very quickly I just hated the image and would rather go to a small tv just so I could see things clearly.
Normal Sky (non-hd) isn't the greatest quality anyway.... so to blast that up in size on a non-hd ready projector.....welll.....
I now have a Sanyo Z5 Hd projector and I love it, amazing clear images on the 360, ps3/bluray film but a big screen at the same time!!
my setup with screens - (360): Dal's Setup
Trust these guys on here, they know what they are talking about! - Your budget is almost there
dalar is offline   Reply With Quote
Old 11-06-2008, 4:48 PM   #9 (permalink)
Thanks: Gave 13, Got 10
2nd hand? because that's amazing!
x liddy x is offline   Reply With Quote
Old 13-06-2008, 2:01 PM   #10 (permalink)
optama ds306
ryt gettin ready to buy an optama ds306 pj will this work with sky and xbox 360??????? write back please
thanks in advance
fatboyslim1992
Old 13-06-2008, 2:22 PM   #11 (permalink)
Thanks: Gave 3, Got 25
Re: optama ds306
Were the helpful suggestions in your other thread not good enough?
Why would you want a cheaper data projector that will limit your connectivity choices in a domestic environment? Save up a bit more and go for one of the projectors suggested in your earlier thread.
dun_buyin is offline   Reply With Quote
Old 13-06-2008, 3:42 PM   #12 (permalink)
leej's Avatar
Thanks: Gave 368, Got 438
Threads merged
My opinions expressed here do not represent those of the AV Forums or its associated websites.
leej is offline   Reply With Quote
Old 14-06-2008, 5:51 AM   #13 (permalink)
Seadog-Peter's Avatar
Thanks: Gave 0, Got 2
As Dun buyin said why would you spend (waste) money on a data projector for a games/home cinema use!
Data projectors have a totally different use in mind ie mostly static power point displays in daylight
If you can't stretch to more than £300 (or save up a bit longer) why not consider a good second hand model - lots of past reviews on this site if you search
Seadog-Peter is offline   Reply With Quote
Old 16-06-2008, 5:19 PM   #14 (permalink)
optama ds306 help with room
hi all,
im goin to buy an optama ds306 pj and also i have a xbox 360 and a sky box for my new room.. will this all attach?
also my throw distance is about 9.10ft-10ft what screen size am i lookin at with the max zoom ratio?
thanks in advance
fatboyslim1992
Old 16-06-2008, 6:15 PM   #15 (permalink)
Re: optama ds306 help with room
You are looking at about a 76" screen at 9.88'. Why the DS306? Why not a HD65? I know it's about £130 more, but the DS306 isn't a HD projector.
And if that 1992 is you Year of Birth then that's the same as me, get a job and buy a HD65, you would be much happier. I'm having trouble finding a job though. My money is slowely decreasing.
ds306, optoma, room
