AVForums - Free Audio Visual electronics advice and information
AVForums.com twitter page AVForums.com facebook page AVForums is a member of CEDIA. THX certified reviewer.  Click for more information. AVForums reviewers are ISF Certified.  Click for more information.
Forum List Register Blogs Information Social Groups Search Today's Posts Mark Forums Read
Go Back   AVForums.com > Forums > Video Electronics > Projectors
Latest popular product pricesPowered by
Epson EH-TW450
Optoma HD200X
Acer X110
Optoma EP761
Epson EH-TW450
Optoma HD200X
Acer X110
Optoma EP761
Optoma ES526
Panasonic PT-AE4000
3M Mpro150
Benq MP727
Optoma ES522
Toshiba TDP-S25U
 More...Prices updated July 30th at 1:30pm and include delivery.
LinkBack Thread Tools
Old 18-05-2008, 5:36 AM   #1
Help Connecting Dell 3400MP DLP Projector!
Hey everyone. I just got a Dell 3400MP Projector tonight.
It has that odd M1-DA input. I wish to connect it to my PS3 to get a 1080i High Def signal, but I have no idea where to start! You can see the M1-DA input and other inputs available below. I'm wondering if I need a M1-DA (VESPA) to HDMI converter - but I don't know if that would work because I don't know if this is HDCP compatible.
http://www.trustedreviews.com/images...ine/1926-2.jpg
Please help me find the cables I need, I spent 2 hours searching to no avail!
Thanks in advance!
Last edited by Zone; 19-05-2008 at 6:57 AM. Reason: image removed please see forum rule #9 thanks
Hubbs604 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookShare on Twitter
Old 18-05-2008, 5:17 PM   #2
Re: Help Connecting Dell 3400MP DLP Projector!
Updated original post!
Hubbs604 is offline
Old 18-06-2008, 6:28 PM   #3
Hey,
Did you happen to figure this out? I'm in the same situation but can't get it going...
I got an HDMI to M1-DA cable, but I still get 'out of range' on the projector. Composite video doesn't work either. So far no success on getting it on the 'big screen'.
edwardkelly is offline
Old 18-06-2008, 7:13 PM   #4
Originally Posted by edwardkelly View Post
Hey,
Yep, I figured it out.
First you need a M1 to RCA - I paid 35 for mine - but monoprice now has them in stock for $4.
CLICK HERE
Then you need an RCA Coupler - which is only another $2.
CLICK HERE
Then if you want to connect computer speakers you need this. Only .65 cents!
CLICK HERE
Then of course you need a component PS3 cable you can get at Best Buy, and this set-up gets you 1080i on the projector!
Hubbs604 is offline
Old 18-06-2008, 7:25 PM   #5
Thanks, You're a superstar.
I had ordered a PS3 to component cable from monoprice the other day when I got the HDMI - M1-Da, so just need the three bits you listed. They were OOS on the 3 in 1 coupler, so I just bought three individual couplers instead.
Now I have to wait for shipping again!
Old 18-06-2008, 7:29 PM   #6
Tell me about it. Mono was out of stock on the M1 to RCA, so I ordered it direct from Dell for $35.00. But price wasn't the worst part - I ordered it May 18th and didn't get it until June 3rd! Glad I could help, it took forever to figure this one out - as you probably noticed the internet had NOTHING!
Hubbs604 is offline
Old 23-06-2008, 5:30 PM   #7
So my new cables arrived, but now I'm having audio problems...
The cable that I have from the PS3 to the projector (via the component to M1 plug) has the component outputs, plus a left and right audio. I fed those into a plug that combines the left/right to a 3.5mm jack. I then plugged my speakers into the 3.5mm jack... The audio that I'm getting doesn't seem like it's all the channels or something. I get some music, but no dialog in some games, only background noise in other games. Any ideas? I set up the audio settings on the PS3 to output via the multi cable. From your suggested plug I'm guessing you run the l/r audio straight into a line in on a receiver or something? Did you have any problems?
Old 23-06-2008, 11:26 PM   #8
I plug the L/R to 3.5 into the "input" jack on the back of the projector itself. then I plug the speakers into the "output" jack on the back of the projector. I have had no problems with this. Let me know if that works.
Hubbs604 is offline
Old 24-06-2008, 12:05 AM   #9
Yeah, I meant to reply to this earlier... In the end that's exactly what I did and it works a treat .
I think the connector that I had originally tried to use was no good, but now it's working just fine.
Thanks again for the help
3400mp, connecting, dell, dlp, projector
Optimised for Firefox
AVForums.com is owned and operated by M2N Limited
Copyright © 2000-2010 M2N E. & O. E.
