Help! - Z1 with HTPC
Old 07-04-2003, 3:29 PM   #1
Underscore
Posts: n/a
This weekend saw me finally sort out my HTPC driving the TV, so I tried connecting it up to my Z1. Set up the PC to output 960x540 @ 50Hz and turned on the PJ. It came up in 'WIDE THRU' mode and, with a bit of tweaking, I got the fabelled 1:1 pixel mapping. Ran Moulin Rouge for a few minutes and just thought 'Wow!' - utterly stunning picture, blowing the 963SA into a cocked hat. I then stored the settings in Mode1.
Anyway, shut down TheaterTek and fired up DigiTV. As it went into full screen, the PJ lost sync and, when it came back, it was in SVGA6 - showing about half of the image and, try as I might, I could not get it to show the whole screen. I've tried a few more times now and have once succeeded in getting 1:1 again, but most of the time it goes into SVGA6, VGA1 or MAC13! There also seems to be no way to recall my Mode1 settings, even when it does correctly drop into WIDE THRU.
Can anyone who has the Z1 working with 1:1 help me out here? Having seen how stunning it was, I can see that the Nirvana that I seek is waiting for me - which only succeeds in making it more frustrating that I can't reach it reliably!
TIA,
_
Old 07-04-2003, 3:55 PM   #2
3,953, Level: 14
Points: 3,953, Level: 14 Points: 3,953, Level: 14 Points: 3,953, Level: 14
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 2, Got 11
Try checking that the refresh rate of the is no more than 60Hz. Whoops, just noticed that you had 50Hz selected.
I had the problem that the PJ wouldn't allow mode1 selection when I was using 72Hz refresh rate. When I dropped it to 60Hz the PJ came up in the right mode. Is it possible that the PC has not kept the 50Hz refresh and has gone up to a higher frequency?
Bill
Old 07-04-2003, 6:38 PM   #3
Underscore
Posts: n/a
Nope, I checked the H & V frequencies that the Z1 was seeing and it was receiving 50Hz. Tried changing to 60Hz and got the same problem.
Tx,
_
Old 07-04-2003, 7:11 PM   #4
8,125, Level: 21
Points: 8,125, Level: 21 Points: 8,125, Level: 21 Points: 8,125, Level: 21
Activity: 6.7%
Activity: 6.7% Activity: 6.7% Activity: 6.7%
Thanks: Gave 3, Got 8
I don't know if this will work, but I'm sure I read a while ago that someone used Zoomplayer and set a custom resolution in there for the Z1.
Good luck,
Dean.
Old 08-04-2003, 1:46 AM   #5
3,953, Level: 14
Activity: 0.8%
I don't know if this will help but these are the settings that I use:
Powerstrip on the PC.
Total pixels 1104
Active pixels 960
Front porch 16 pixels
Sync width 32 pixels
Back porch 96 pixels
Scan rate 33.784 KHz
Refresh Rate 60.007 Hz
Total lines 563
Active lines 540
Front porch 2 lines
Sync width 6 lines
Back porch 563 lines
Projector settings
Fine sync 11
Total dots 1104
Horizontal 133
Vertical 21
Display area H 960
Display area V 540
Full screen ON
These work consistently for me, but I did have a bit of aggravation getting there.
Good luck.
Bill
Old 08-04-2003, 1:30 PM   #6
Underscore
Posts: n/a
Thanks. Last night I turned off powerstrip and just selected the 960x540 resolution in the display settings. The PJ then seemed to sync up OK. Hopefully that means there was a problem with my PS settings - though all I had done was to change the refresh rate. Assuming that now works reliably - I didn't have too long to play last night - I think that I will watch a couple of movies before I try to fine tune PS. It'll be really useful to have your settings as a starting point for when I do get adventurous again!
Tx,
_
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
6 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
 Updated February 10th at 6:30am. Prices include delivery.
