| Re: Window rear-projection recommendation
If its at night then that pretty much changes everything. Although you have to deal with street light and other signage something like a pansonic ax200 which has 2000 Lumens will do, those are <£800 or look at some of the cheaper business projectors, if your showing mainly graphics and not video these would do fine. The optoma hd65 has 1600 Lumens and can be had for super cheap, but as its DLP you risk giving potential customers RBE. Then again most pubs i've noticed recently use mitsubishi DLP's and they aren't really throwing many rainbows, certainly packed with customers on a match day. Big bright image too although i think these are 4000+ Lumens models, but as you only need a small screen illuminated this shouldn't be anywhere near necessery.
Places like ebuyer have quite a few business projector models with greater than 2000 Lumens , and although not great fedelity wise for video they should do fine for a there target job of displaying graphics and charts ect... just things like skin colours wouldn't really look right and video may have artifacts from poor electronics for de-interlacing and scaling. These are normaly loud, but if its only on when the shops closed its harly a problem. The advantage is that they are very cheap usualy.
