Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Toshiba TDP-S25U
Benq W1000
Sanyo PLV-Z700
Optoma HD65
Toshiba TDP-S25U
Benq W1000
Sanyo PLV-Z700
Optoma HD200X
Acer X110
InFocus Play Big X9
Optoma HD20
Panasonic PT-AE3000
Epson EMP-TW700
 More...Prices updated November 24th at 1:30pm and include delivery.
optoma hd65 stevey27 Projectors 50 09-07-2009 8:17 AM
Optoma HD65 or HD720x erv2 Projectors 40 16-06-2008 10:08 AM
optoma hd65 connection problem JimBo2741 Projectors 0 02-04-2008 7:55 PM
Onkyo 875 & Optoma HD65 - Can anyone help? De1l Onkyo Owners' Forum 6 21-01-2008 10:27 AM
Old 07-04-2008, 11:57 AM   #1 (permalink)
Thanks: Gave 2, Got 0
Optoma HD65 Distance Problem
Hello all,
I was all ready to buy an Optoma HD65 projector until I measured the distance from where I sit to the screen. If you guys can help out with 2 issues that I have.
1) Basically, the screen is 145cm long. Therefore, according to the distance calculators that would put the projector between 2.83 and 3.13. That range is exactly where our sofa is!!
2) I have purchased an electric screen that I will suspend from the ceiling. It is in the format of 4:3 and is 72 inch. I will have to just live with the white area when watching in 16:9 mode. The second problem is that when the screen is down it is still very high. Infact the bottom of the screen is about 10-20 above our heads. Again, this I would live with. The problem is that I have read that keystone is not good to use. The projector will probably be on the coffee table and therefore I assume that I would need to use keystone if i somehow was able to shift the sofa a little.
Given the 2 above. What should I do? The reason why I looked at the HD65 was the price to be honest. Any recommendations on other Projectors if that option would be better. I will be using only to watch movies. And I would prefer to have 720p. Cheaper the better. Thanks in advance for all your help.
prak is offline   Reply With Quote
Old 08-04-2008, 11:39 AM   #2 (permalink)
Re: Optoma HD65 Distance Problem
Hello,
Just looking into this problem. When I went to projectorcentral.com and used the distance calculator it came up with the values as described in my orginal post. However, not thinking it would be different, I went to http://www.optoma.co.uk/distancecalc.aspx
and the values are coming in at 2.13m to 2.46 for a 166cm diagonal screen. This would be possible to fit in my room. But the projector would still be much lower than the screen. Approx, 1m lower. Would this be a problem?
Also, can someone please confirm because a couple of sites differ from the Optoma values.
Regards,
Prakash
Old 08-04-2008, 11:44 AM   #3 (permalink)
Thanks: Gave 20, Got 22
It will be fine on a coffee table as the amount of keystone correction wont be too high. As for other pj's around the price of this one ( up to 700) i can't think of a better option, watching films on it is great - also gaming is fantastic through ps3 hooked up with hdmi. Buy and enjoy!! See the optoma thread for details on the best prices.
Drive for show, putt for dough!!
merlincoops is offline   Reply With Quote
prak (09-04-2008)
Old 08-04-2008, 2:39 PM   #4 (permalink)
Thanks: Gave 53, Got 146
Originally Posted by prak View Post
Hello,
Regards,
Prakash
I have just checked Projector Centrals data and Optomas manual online and they both give the same throw range of 2.24-2.46 metres for a 166cm diagonal screen.
jacko5 is offline   Reply With Quote
prak (09-04-2008)
distance, hd65, optoma, problem
