Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD200X
Optoma Pico
Epson EMP-TW700
Panasonic PT-AE3000
Acer X110
Optoma ES522
 More...Prices updated November 21st at 2:30pm and include delivery.
cant get a pic on hd70 deltuna Projectors 3 12-12-2007 9:36 AM
Another HD70 Screen question Steviefull Projector Screens 5 19-10-2007 7:26 AM
hd70 microdigitec Projectors 2 23-07-2007 7:37 AM
Simple HD70 lamp question Tommy Angelo Projectors 5 08-05-2007 8:14 AM
Old 24-01-2008, 2:42 AM   #1 (permalink)
Thanks: Gave 1, Got 0
+Sorry for anothother HD70 Question
Sorry I am new to projectors and home theater setups. I am trying to build a theater room in my basement. I bought an optoma hd70 and I am going to buy an onkyo tx-sr605. My question is will i be able to connect a toshiba hd-a2 dvd player, my cable box, and my xbox to the 605 without running all kinds of cables from the projector, or would i need a different reciever to eliminate the different cables from the projector, or is this impossible with the projector i have purchased?
I just dont feel like running many cables 20ft. across the room. Again sorry if this is a dumb question
Rdurkin05STI is offline   Reply With Quote
Old 24-01-2008, 7:25 AM   #2 (permalink)
Thanks: Gave 87, Got 37
Re: +Sorry for anothother HD70 Question
Yes me too,i have the same set up and i need some tips for all the connection[sky,elite,ps3,wii].hope someone is soo good to maybe post some pics too thanks
marshall_nathan is offline   Reply With Quote
Old 24-01-2008, 10:01 AM   #3 (permalink)
chic's Avatar
Thanks: Gave 101, Got 716
an onkyo 605 should do the job ok, you would connect the hddvd player straight to the 605 hdmi socket, you would then connect the 360 using component to one of the component sockets on the 605 and you would connect the optical as well to the 605 for audio. With you cable box if its an hd box you would just use hdmi and optical, if its a standard box you could get a scart to svideo cable and use that and use r+l phono out for audio.
You would then run one long cable from the 605 to the projector and it should work fine.
In my set up i have an hd 70 projector and i have a sony 910 amp, to my amp i have connected my sky hd,toshiba he1 hddvd player,my ps3 and my xbox 360, i just run 1 10m hami cable to my projector and i can view all my sources on the projector just usin the sony amp to do the switchg.
Samsung UE46B7000 ,Optoma hd70,,SVS SB12 Plus ,Onkyo 876,Mordaunt Short Avant 906i, Mordaunt Short Avant 905,Mordaunt Short Avant 903i ,Mordaunt Short 902i,Skyhd,PS3,XBOX360,HE-1, E-30,XBOX360,Oppo BDP-83,Samsung BDP1500,Harmony one remote
chic is offline   Reply With Quote
Rdurkin05STI (24-01-2008)
Old 24-01-2008, 3:13 PM   #4 (permalink)
thanks, yes my cable box is an hd box so i would want to connect it using hdmi, i have the hdmi cables i need i guess i just need to get the two optical connections for the 360 and cable box
Old 24-01-2008, 3:33 PM   #5 (permalink)
chic's Avatar
yes you would
anothother, hd70, question
