| Re: optoma hd65 flickering????
Since my projector came back I have not noticed any flickering. However, I have only played a game or two on the xbox and watched a short film, so i'm reluctant to say it is perfect yet... but I am very hopeful it is sorted, and very glad it is back.
According to the tech guys, it has had a new colour wheel... and then when it was going through QC it ended up getting a new lamp as well (as the first one failed the check).
Only downer is since coming back the lens is now a little loose, such that when I focus the image with the dial, the picture can sometimes shifts left and right/up and down as well. This would probably be more annoying if I had a screen, and I'm not sure I fancy loosing it for another period of time.
If you do send off for repair, ask for a hot swap. It could end up being longer than the number of days they quote. Good luck!
