Projectors on coffee tables
Old 21-01-2008, 12:43 PM   #1
Illustrious Member
Pecker's Avatar
43,919, Level: 51
Points: 43,919, Level: 51 Points: 43,919, Level: 51 Points: 43,919, Level: 51
Activity: 20.8%
Activity: 20.8% Activity: 20.8% Activity: 20.8%
Thanks: Gave 2,680, Got 1,885
I'm currently removing my projection system from my dedicated Home Cinema room and installing it in my living room.
To cut a long story short, I'm going to have to put the projector on a coffee table when in use, and put it away therest of the time.
I can find lots of threads on mounting projectors, but not on putting them on coffee tables.
I was just wondering what experiences people have had with this, either as users or installers.
Any pros & cons?
Steve W
Old 21-01-2008, 12:59 PM   #2
PeteIvy's Avatar
4,799, Level: 16
Points: 4,799, Level: 16 Points: 4,799, Level: 16 Points: 4,799, Level: 16
Thanks: Gave 44, Got 49
Re: Projectors on coffee tables
I can't see you having any problems. I used to do exactly the same. The only annoyance I had was worring about tripping over the cables, or forgetting the projector is there, sticking my feet up on the table and kicking it off (thankfully I never actually did this, but did come close a couple of times!)
Old 21-01-2008, 1:15 PM   #3
Assured Advertiser
Liam @ Prog AV's Avatar
27,664, Level: 40
Points: 27,664, Level: 40 Points: 27,664, Level: 40 Points: 27,664, Level: 40
Activity: 1.3%
Activity: 1.3% Activity: 1.3% Activity: 1.3%
Thanks: Gave 6, Got 803
I had this in an old place of mine. Coffee table had 4 stumpy fit, and I made four tiny impressions in the floor that these would just fall into nicely when the coffee table was in the exact right place for the projector. The projector was built into the underside of the table itself, and the cable ran on a small bit of visible cable cover from the coffee table to the sofa, and then under the sofa and around to the kit rack. The right kind of floor and you could very easily lift up a single floorboard and run the cabling that way.
Higher budget will allow for motorised coolness! A coffee table which lifts up 6-12" to bring the lens up to height, or a motorized flap at the front to protect the projector when not in use are things I have done before for clients.
How much does a cockney pay for shampoo? Pantene
call me: 01892 860801 / e-mail me: liam@progressive-av.com / twitter me: @ProgressiveAV
Progressive Audio Visual Ltd and AVToad.co.uk are proud to be AVForums Assured Advertisers.
Old 21-01-2008, 1:52 PM   #4
2,650, Level: 11
Points: 2,650, Level: 11 Points: 2,650, Level: 11 Points: 2,650, Level: 11
Thanks: Gave 2, Got 5
I sit my PJ on a coffee table when in use and I don't find it much of a chore. I know approxiamately where it needs to sit to get the picture size I want so once it's all plugged in and turned on it's usually a 2 minute job to focus etc. If you've had a ceiling mount before then you might find it tedious to do this each time you want to watch a film but personally I don't find it a problem.
Obviously throw distance and the distance between your seating and the screen may make things awkward, ie the table may be too close and get knocked by your feet.
Old 21-01-2008, 2:26 PM   #5
3,581, Level: 14
Points: 3,581, Level: 14 Points: 3,581, Level: 14 Points: 3,581, Level: 14
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 18, Got 6
What about the height of the projector vs the screen. Lots of DLPs have fixed offsets, others will not be able to shift enough vertically. Should this not also be an issue for Pecker??
Jim
Old 21-01-2008, 2:35 PM   #6
Assured Advertiser
27,664, Level: 40
Activity: 1.3%
He has a HD73 which offsets 36% ish upwards, so going under the coffee table will be fine so long as the top of the table doesn't overhang too much and leave a shadow at the top of the image.
Old 21-01-2008, 2:51 PM   #7
Illustrious Member
sdb123's Avatar
31,232, Level: 43
Points: 31,232, Level: 43 Points: 31,232, Level: 43 Points: 31,232, Level: 43
Thanks: Gave 1,578, Got 2,031
I have used a table from our nest of tables and it has worked well for me.
Old 21-01-2008, 3:48 PM   #8
3,581, Level: 14
Activity: 3.8%
Liam,
Are you saying that if he places the projector below the level of the bottom of the screen, he will still be OK? I am interested in this, as I thought only LCDs would be suitable for me / or very expensive LCOS. I have a custom built cabinet which has the projector at around 60cms off the ground. The screen is 3.6m away from the projector, and the bottom of the screen is around 80cms from the ground.
Would I get away with an HD73 / or something similar (H79)?
James
Old 21-01-2008, 4:46 PM   #9
Illustrious Member
Pecker's Avatar
43,919, Level: 51
Activity: 20.8%
A big thanks to everyone for all of your input.
I was thinking if having it on top of the coffee table, the right way up (on its little feet).
I'm not very good at the maths on this one, I'm afraid. Can any of you geniuses help?
Distance from lens to screen will be c.3.7 meters.
Screen size will be c.234cm wide & 132cm high - hence on maximum zoom, according to Optoma's online Distance Calculator.
The bottom of the screen needs to be at least 60cm off the ground, but 85cm+ would be even better.
Is this do-able? What height would the coffee table need to be?
Clearly, only people with degrees in applied Maths or sophisticated spreadsheets need attempt to answer.
Cheers.
Steve W
Old 21-01-2008, 5:56 PM   #10
4,175, Level: 15
Points: 4,175, Level: 15 Points: 4,175, Level: 15 Points: 4,175, Level: 15
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 62, Got 162
Cheers.
Steve W
Assuming your PJ is an HD73 and assuming the offset is 36% and assuming your image height is 132cms., the image will have an upwards offset of 47.5cms. Therefore, if you require the bottom of the image to be 85cms off the ground your table will need to be 38cms high, or if you prefer, 15inches.
Pecker (21-01-2008)
Old 21-01-2008, 7:52 PM   #11
Assured Advertiser
27,664, Level: 40
Activity: 1.3%
Exactly as Jacko said. Offset is % of height, and is outside of the viewable area. So if anything, putting a HD73 on top of a coffee table puts the projector higher than expected (assuming the average coffee table is about 18-24" tall. But inside or under just works and is much cooler effect when someone comes round and can't see where the projector is
Pecker (21-01-2008)
Old 21-01-2008, 8:48 PM   #12
Illustrious Member
Pecker's Avatar
43,919, Level: 51
Activity: 20.8%
The figures you're quoting suggest my initial ideas were just right.
Many thanks for your sage-like advice.
Steve W
Old 22-01-2008, 2:01 PM   #13
2,650, Level: 11
There's always a large book or catalogue lying about you could use to increase the height by a few inches too.
Old 22-01-2008, 2:26 PM   #14
sapper's Avatar
20,094, Level: 34
Points: 20,094, Level: 34 Points: 20,094, Level: 34 Points: 20,094, Level: 34
Activity: 19.3%
Activity: 19.3% Activity: 19.3% Activity: 19.3%
Thanks: Gave 432, Got 139
Ahhhh the old low tech solutions always have a certain appeal, but are not beaten by the cool, the wow factor of motors whirling away, only to fail
Adrian
Old 22-01-2008, 3:17 PM   #15
Assured Advertiser
27,664, Level: 40
Activity: 1.3%
Actually depending on the size of Steve's coffee table he may need to lower rather than raise to counter the offset of the ThemeScene....
Old 22-01-2008, 3:49 PM   #16
Illustrious Member
Pecker's Avatar
43,919, Level: 51
Activity: 20.8%
Maybe I should just put the projector on the thick book and forget about the coffee table.
The height of the image on the wall isn't too much of an issue. The wall is c.2.4m tall, and as long as the bottom is over 60cm (preferably over 85cm) off the ground, that's fine.
Obviously, with the image being 132cm high, and the casing of the screen being c.10cm. the bottom can't be any higher than c.100cm off the floor, or we'd be projecting onto the ceiling.
BTW, the reason for having two minimum heights is as follows.
We have two things at the front of the room that the image has to clear (be above). The equipment rack (on which you'll find the players & the centre speaker) is c.60 cm off the ground, so the image must be above that.
The front left & right speakers are floorstanders, at 85cm high each. It would help if the image cleared those. However, it's not vital as the image will fit in between the two speakers if necessary, with the speakers standing between the edge of the image and the side walls.
Steve W
Old 22-01-2008, 3:55 PM   #17
Assured Advertiser
27,664, Level: 40
Activity: 1.3%
I've got my standmounts left and right of the screen, and the centre on a wee 20cm Alphason stand resting on Mo-Pads to tilt it up slightly. The screen can then lower right down in front of the plasma and down to about 50-60cm from the ground. Perfect! I hate looking up too much at a screen
Old 22-01-2008, 4:08 PM   #18
Illustrious Member
Pecker's Avatar
43,919, Level: 51
Activity: 20.8%
Me too, which is why I may well go for that option.
Steve W
Old 22-01-2008, 6:59 PM   #19
Conspicuous Member
Gary Lightfoot's Avatar
27,924, Level: 40
Points: 27,924, Level: 40 Points: 27,924, Level: 40 Points: 27,924, Level: 40
Activity: 18.6%
Activity: 18.6% Activity: 18.6% Activity: 18.6%
Thanks: Gave 42, Got 519
You could always have it inside the coffee table so that it's hidden (like a box), but allows airflow in and out. I've CRTs done this way and sopme have a flap on the front, so when not in use it's totaly hidden. When you need to watch it you just open/remove the flap. You could even route the cables under the carpet and into the table so they're not even visible as well.
Gary
Old 22-01-2008, 7:13 PM   #20
Illustrious Member
Pecker's Avatar
43,919, Level: 51
Activity: 20.8%
Gary
Cheers, Gary. I've seen them - they look pretty flash.
Sadly, the coffee table is going to have to be right in front of the sofa whilst in use, and subsequently will have to live elsewhere when we're not watching a film.
Steve W
Old 22-01-2008, 8:02 PM   #21
2,355, Level: 11
Points: 2,355, Level: 11 Points: 2,355, Level: 11 Points: 2,355, Level: 11
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 28, Got 25
Yeah, big room to keep the coffe table in the middle of the room and still have a reasonable projection...
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
5 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
 Updated February 10th at 4:30pm. Prices include delivery.
