Originally Posted by u02ai Quite happy with the ptae1000 but the blacks could be better and I find it quite dull on anything other than the normal, dyanmic and cinema 3 settlings. Saying that I havent calibrated yet as I was planning an ISF calibration when my room is finished and I get a screen.
the upside of upgrading would be that It seems that I could easily swap the projector with the existing mount with minimum hassle. Do you think that there is enough of a difference between the 2 models to warrant a swap? |
I've just got my AE2000 today, but it's been some time since I saw my AE1000 in operation, so memory might be playing tricks (plus placebo effect possibly
). I reckon the 2K is brighter (not just because of the new lamp either), sharper and has a couple of nice operational tweaks like the split screen mode for seeing what the adjustments are doing to the picture. I don't think the black level is any lower, but I use an ND2 filter anyway which brings it down to a level I am happy with, the brighter whites of the 2K give an overall boost to the contrast compared to the 1K.
When you get a screen, it might be worth looking for one with positive gain (mine is 1.8) as I'm guessing you are using a wall at the moment? When you have the picture framed with the black border I think it makes the contrast
appear better too. Also try using the waveform monitor in single line mode (the top option IIRC) to set the brightness and contrast correctly...it makes all the difference.
Only you can deceide if the cost is worth it. I was lucky in that the change cost me about £650 as I bought mine in the Audio T sale for £1900. I've been without a PJ for a while too so that wasn't fun.
I don't know how much you'd get for your AE1000 now that the AE2000 is out and reviews in What Hifi, etc are praising it so much...doesn't help the resale. My approach was to convince a friend to spend a little more than the AX200 and to get a hardly used 1080p machine....he definately wasn't going to spring for the whole £1,900 a new AE2000 would cost so it was a good deal for him (and me
