| Re: Help with Themescene HD81 setup
Ceiling heights vary as do projectors image offsets so it's not always possible to make a lens mount for every situation.
If you can get the projector close to the ceiling that would help, but it may mean modifying the existing ceiling mount or making your own unless you can get the screen higher to fit where the image falls.
The angled sides of the image are there because you have tilted the projector up, so the top is further away from the lens than the bottom. You can use the projectors keystone facility but although this can straighten the sides it can sometimes introduce some odd image artefacts so most people try not to use it and I wouldn't recomend it.
Without seeing the images on your screen it's hard to tell what may be wrong, but with normal DVD and tv transmitted stuff which is standard definition, I would try to use a projector mode which makes them all fill the screen. If any mode is bigger than the screen then the projector is too close or zoomed too close. If you use the projectors own output (if it has it) without any inputs active, you should be using the whole panel of the pj, and then use that with the zoom to fill the screen. It will be easier with the pj being square first though, so sort out the ceiling mount first.
I think I sw someone having a similar problem with the HD1 and PC not too long ago, so try the search and see what comes up. Powerstrip may be the program you are thinking of which can give you custom timings and resolutions.
HTH
Gary
