Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
InFocus Play Big X9
Acer X110
Optoma HD200X
Optoma HD20
Optoma HD700X
Panasonic PT-AE3000
 More...Prices updated November 24th at 8:30pm and include delivery.
Help!!!!!! Panasonic AX100, Themescene HD73 or Infocus IN76!!!??? N0RTHERN M0NKEY Projectors 4 13-04-2007 9:26 PM
Panasonic DMR-EX85 and Optoma patt DVD and Blu-ray Recorders, Recording and Media 0 08-04-2007 5:10 PM
Panasonic DMR-EX85 and Optoma patt Projectors 0 08-04-2007 5:07 PM
Optoma HD73 With DC3 RamonD Projectors 57 30-01-2007 12:57 PM
Panasonic AE900 and Panasonic GS500 OR Optoma HD72i matthewpscott Projectors 2 20-06-2006 10:30 PM
Old 10-12-2007, 11:50 AM   #1 (permalink)
optoma hd73 or panasonic ax200e
I'm torn between these two projectors for my first purchase. hd73 is more "cinema like" and panny is more flexible...HELP!
stuart cocker is offline   Reply With Quote
Old 10-12-2007, 1:18 PM   #2 (permalink)
chic's Avatar
Thanks: Gave 101, Got 718
Re: optoma hd73 or panasonic ax200e
i want from lcd i had an old panasonic a300 and went for the cheap optoma hd70, i prefer the dlp image to the lcd one, the other thing that swayed me was the problems you will get from degradation of lcd panels over time due to heat. You wont get this from lcd and dlp projectors are less prone to dust problems than lcd. However the disadvantage with the dlp is the longer throw need to get the same size image, with my lcd projector i could get a 106" diag image from around 12ft,whereas with the optoma from the same 12 ft i can only get a 92" diag image.
So you need judge whats better for you, no doubt the panasonic and the optoma will produce great images, you just need to judge whats more important for you.
Samsung UE46B7000 ,Optoma hd70,,SVS SB12 Plus ,Onkyo 876,Mordaunt Short Avant 906i, Mordaunt Short Avant 905,Mordaunt Short Avant 903i ,Mordaunt Short 902i,Skyhd,PS3,XBOX360,HE-1, E-30,XBOX360,Oppo BDP-83,Samsung BDP1500,Harmony one remote
chic is online now   Reply With Quote
Old 11-12-2007, 2:59 PM   #3 (permalink)
Thanks: Gave 20, Got 10
If you're planning to use the hdmi connection you may wish to be aware of this thread. Although I started it because of the described problem with the AX100, it appears to still be an issue with the AX200.
AX100 Green/Purple Flash with HD DVD
chappies is offline   Reply With Quote
ax200e, hd73, optoma, panasonic
