Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
InFocus Play Big X9
Acer X110
Optoma HD200X
Optoma HD20
Panasonic PT-AE3000
Optoma Pico
 More...Prices updated November 25th at 5:30am and include delivery.
Old 05-11-2007, 11:05 AM   #1 (permalink)
Doctor Smith's Avatar
Thanks: Gave 162, Got 31
Blacks on LCD projector
What are the blacks like on a £800 lcd projector ie sanyo or Panasonic are they like LCD tvs blacks or better
Doctor Smith is offline   Reply With Quote
Old 06-11-2007, 1:13 AM   #2 (permalink)
Gae
Thanks: Gave 1, Got 28
Re: Blacks on LCD projector
About the same to better, but not perfect.
I spent ages calibrating both my graphics card overlay settings and the settings on my Panny AE900. After hours and hours of tweaking I eventually found settings that I was happy with. I set the Brightness to quite low and the contrast to quite high on both card and projector and I get a pretty good depth of dark to light. It isn't jet black for sure but as good as possible on an LCD.
Good calibration is very important.
Gae
Too much information.....and not enough time!!
SKY HD,Panasonic AE900, Samsung LE27T51B, XBox, XBox 360 HD-DVD drive, Samsung DVD HD850, Samsung DVD E232, JVC S-VHS HR-S6600EK, Pinnacle PC-TV, Twinhan DVB-S capture cards, DVBViewer with BBC HD
Gae is offline   Reply With Quote
Old 06-11-2007, 8:40 AM   #3 (permalink)
spooney's Avatar
Thanks: Gave 53, Got 220
My Sanyo is calibrated to 65k and has a glass filter to compensate.
My room is light-controlled and I use a grey DYI screen, which adds to heavy blacks.
I found the blacks too dominant in many scenes and changed a player setting to cut back a bit. My next screen will be white
________________
It is not the fall that kills, it is the sudden stop...
________________
spooney is offline   Reply With Quote
Old 06-11-2007, 8:59 AM   #4 (permalink)
Super Moderator
Thanks: Gave 465, Got 946
Depends how dark you can get your room. No projector can compensate for ambient light spilling onto the screen. In this respect, no projector can be "as good" as a direct view screen.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
Old 06-11-2007, 4:59 PM   #5 (permalink)
Thanks: Gave 38, Got 133
It should be better than than LCD TV (at least any i've seen recently) but will not be as good as a good plasma (i.e. one that cost more than said projectors and gives a much smaller image) and can't compete with good old CRT.
Most people find the lastest LCD projectors have a decent and certainly livable black level, if you want better you'd have to move to a good DLP or a DILA. The newer 1080p LCD's appear to have improved on the black levels again.
gazbarber is offline   Reply With Quote
blacks, lcd, projector
