| HS10 Review
At long last I have everything up and running, I have been waiting on a screen arriving before setting it all up properly.
My Setup.
HS10 DIY ceiling mount, cinema filter fitted,settings adjusted from Dave Boswells posts on AVS.
Draper Luma matte white 72" by 40.5" 16:9 manual screen
10 feet distance from projector the image fills this perfectly.
An old Hitachi 250e dvd player connected by pj multi int s-video.
Picture Quality.
No screendoor from 10 feet distance.
I first tried it out on a mates Toshiba 210e via component the picture was very clear and detailed but it suffered from jaggies and quite badly from the chroma bug, the reds were terrible but overall the picture was very good indeed.
The Hitachi connected via s-video is watchable but I must get a
high quality dvd player soon.
( some adivce would be most welcome)
After I changed the % settings from Dave Boswells calibration infothe colours were far better and the shadow detail was also improved over standard, I would advise doing this to your own machine unless of course you can calibrate the HS10 yourself.
( Just remember to note down your original settings )
Fan Noise.
I sit directly bellow the projector even in the quietest of scenes the fan just does not bother me, with a little bit of volume in a film the fan is not heard at all.
Dead Pixles.
None.
