| Loud humming Noise from LG DLP
hi all
our DLP stopped working and we changed the globe and it now owrks again, however the other problem it has is there is a humming noise (that we have had for a long long time actually) that is at best rather annoying, but at other times sound like its a real problem.
the first time i started it with the new globe it ran for 15 mins and then the nosie was so bad i turned it off as i thought it would blow up.
I checked the cooling fan thinking that was the problem, but it is fine.
I have heard aobut a "colour wheel" that can be noisy.
Does any one know aobut this and what can be done?
thanks in advance
Kev
