Projector Novice...
Old 07-01-2003, 6:48 PM   #1
beng
Posts: n/a
Projector Novice...
...looking to get into the world of truly large Home Cinema.
Budget - 1500
Project experience - zero
What sort of features should I be looking to get for that price point?
Is it worth saving up a bit and spending more cash?
Am I an idiot for not knowing any of this already?
Old 08-01-2003, 12:16 AM   #2
6,509, Level: 19
Points: 6,509, Level: 19 Points: 6,509, Level: 19 Points: 6,509, Level: 19
Hi Beng
Nope you are not alone in not understanding what to look for .I was exactly the same , not a clue , all I knew was that I wanted a bigger movie experience in my frontroom .I used sites like this to find out what to look for , the faq's are a good place to start for the basics . Basically I went out and found a place that would give a good demo . Had look at the sony vpl hs1 cost about £1400 or less if you hunt around .Ended up getting the slightly newer sony vpl hs2 £1240 .A lot of members seem to have the panasonic ae100 or the new sanyo z1 both are cheaper than the hs2 I think ( though not as good looking imho).I won't embarrass myself by trying to go into the technical stuff as there are a lot of people on this forum who can help you a lot more then I can . I'm sure you will get a lot more replies as the night wears on . Cheers murph
Old 08-01-2003, 6:26 AM   #3
Conspicuous Member
Gary Lightfoot's Avatar
27,924, Level: 40
Points: 27,924, Level: 40 Points: 27,924, Level: 40 Points: 27,924, Level: 40
Activity: 18.6%
Activity: 18.6% Activity: 18.6% Activity: 18.6%
Thanks: Gave 42, Got 518
Demoing is the most important thing.
The two most common types of digital projector are the DLP and LCD ones.
Each has its' own good and bad points, and there are two ways to look at this - to be ignorant of the bad points, and judge the pj on the picture you see, or know what to look for and be more critical of the images, and look for things you wouldn't have noticed before.
Sometimes ignorance is bliss - not knowing about something means you won't be looking for it, and probably won't notice it.
But if you do want to know, here are the basic differences:
LCD:
screendoor - the gaps between pixels are bigger on LCD than DLP, so seating distance is recommended to be 2 times screen width. Can be fixed by a slight defocusing of the lens, and in some cases, with a different screen or a lens filter. The latter two really only tend to be noticable as a comparison against a white screen.
Contrast ratio - the difference between the darkest 'black' and whitest white seems limited to around 1000: currently on these machines.
Black level - all bulb projectors pass light in one way or another. Black looks dark grey.
Green push. Some LCDs can tend to have a green tint to the image. Can be fixed with an FLD lens filter & recalibrating.
Banding - vertical lines within the image.
Dead pixels - having a bright blue, red or green pixel (or combinations of) staying stuck on, slap bang in the picture (center is worst place) can ruin the image. LCDs can come with these from new or develope them after a period of time.
DLP:
Screen door from less than 1.5 viewing distance,
Black level - generaly better than LCD but still not true black.
Rainbow effect - the biggest deal killer for this technology. Because the image is built up one colour at a time via a colour wheel and thousands of tiny mirrors reflecting light on and off at a very fast rate, you generaly just see the mixed resultant colour. Some people unfortunately can see the colours seperately and see a rainbow tiype artefact around certain parts of the image; normaly where there is a change from lighter to darker parts of the image.
Headcahes/ eye strain. Another effect of the colour rendition process.
Temporal dithering - IIRC the mirrors of the DLP chip trying to make better contrast over a period of frames causes a mosquito effect or noise in the image - mainly in darker background areas I believe.
Some older DLPs appear to produce orange reds and washed out colours (due to white section in colour wheel).
These issues make either technology sound unfit for purpose, but in fact they are rarely issues at all, otherwise nobody would buy them. other factors to look/listen for:
Fan noise. Less than 30dbs seems acceptable to many (depending on how close you are of course)
Throw length. Distance the pj lens allows the pj to be to the screen for the required screen size.
In built scaler/deinterlacer. Some (older) pjs aren't good at these, so show stair-stepping on edges like round objects. An external processor will do a better job in these cases (like a suitably equipped PC - an HTPC).
That's some basic things (I've probably missed some I'm sure), but you'll find other things the more you read, so demo as many as possible to get a feel for the technologies.
In most cases though, you'll fiind they're all pretty good, but depending on your own preferences, some will be better than others (to you).
There are currently a lot of home theater specific pjs that have addressed a lot of these problems to one degree or another, and are becoming increasingly cheaper. You'll see some of them being mentioned, along with the prices, so you can get some idea of what models to try to demo.
Pictures of screen shots don't show the true picture, especialy for black level, but can be used as a guide. Nothing beats seeing one for real though.
HTH
Gary.
Old 08-01-2003, 2:23 PM   #4
MrSafety
Posts: n/a
Hi from another newbie.
I got a VPL_HS1 for £1150 and am very happy with it. Based on my last few weeks of surfing and scanning boards like this and other info sites I would agree with the comment above about "ignorance is bliss". The deeper you look into any of these things the more you wish you hadn't.
I also got a LG-3620 home cinema system for £200; so my combi comes in under your budget and I am well chuffed with it. LG may not be a Sony or Panasonic brand but I bought one of their cheapo VCRs for my kids to watch Disney videos on last year and was so impressed I am now an LG fan.
cheers
Old 09-01-2003, 1:40 AM   #5
MAW MAW is offline
MAW's Avatar
36,120, Level: 46
Points: 36,120, Level: 46 Points: 36,120, Level: 46 Points: 36,120, Level: 46
Thanks: Gave 26, Got 490
Your £1500 to cover sound and vision? It's quite tight, but a trip to somewhere like richers should stretch the audio/dvd player side of the budget, leaving you able to afford one of the previously mentioned PJ's, they're all pretty good these days. When you get to nitpicking, it's time to come back here to ask about upgrading! Personally I'd rather add a bit to the audio budget and go for separates, maybe for projection a tosh DVD player, as they do component video, never mind all that stuff about progressive scan, you'd not see a difference without lessons, ie it's a giant picture in you front room, it's great! Then budget amp and speakers, you'll get a better sound than an all in one. Don't forget to count the cost of cabling it all, projector cable runs are usually long and worth reasonably good cables.
Old 09-01-2003, 5:43 PM   #6
beng
Posts: n/a
Thanks guys for the intelligent and considered replies.
Old 09-01-2003, 9:23 PM   #7
6,847, Level: 19
Points: 6,847, Level: 19 Points: 6,847, Level: 19 Points: 6,847, Level: 19
If you are on a budget the Panasonic PT-AE100 is back for <£1000
here:
http://www.komplett.co.uk/k/ki.asp?a...1&p=20225&s=fp
They also do a couple of resonable priced screens too.
Of course the real budgeteer goes for the DIY screen though .
-- Jon
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
6 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
 Updated February 10th at 7:30am. Prices include delivery.
