06-07-2007, 12:19 PM
#1 (permalink)
| | New Member
Thanks: Gave 2, Got 1 | Themescene 80 vs Panasonic 1000e
I am in a position to buy a 108p projector and I am torn between the panny and the HD80. From a price perspective the panny comes in a 2.5k whilst the HD80 is 2k. I would pay the extra £500 if I thought it was worth the extra. I am not an expert and I fear a short demo may not be conclusive.
I would sooner buy on reccomendation from experts. I dont mean to be derogatary to the retailers - I know many add invalubaly to the forums but I know they can also be biast.
I will be seated between 10-15 feet watching an 8ft wide screen...
06-07-2007, 12:27 PM
#2 (permalink)
| | Conspicuous Member
Thanks: Gave 335, Got 1,053 | Re: Themescene 80 vs Panasonic 1000e Quote:
Originally Posted by max7 I am in a position to buy a 108p projector and I am torn between the panny and the HD80. From a price perspective the panny comes in a 2.5k whilst the HD80 is 2k. I would pay the extra £500 if I thought it was worth the extra. I am not an expert and I fear a short demo may not be conclusive.
I will be seated between 10-15 feet watching an 8ft wide screen... | Demo, demo, demo and then just to be sure demo again. At the end of the day it's the image that your prefer that counts. DLP and LCD produce a different "style" of image and some prefer one to the other. Some other things -
DLP PJ's tends to be less flexible with regard to PJ mounting/screen position as they usually have less lens shift or longer throw which may/may not be a consideration.
The noise level produced by the PJ when operating may also be a consideration.
Also some people are affected by what is called "RBE" or raindows with single chip DLP. This is because a single chip DLP uses a very fast spinning wheel with different colour segments to produce colours on screen. Some people see muti-colour rainbows on the edges of moving objects or areas of high contrast. Not everyone is affected but if you or your family are it could be a problem.
Go see/hear them in action and take along familar material to test.
AVI
06-07-2007, 12:44 PM
#3 (permalink)
| | Assured Advertiser
Thanks: Gave 31, Got 26 | Re: Themescene 80 vs Panasonic 1000e
Hi Max7
The HD80 vs. PTAE1000. The HD80 really is in a league of it's own. Giving a brilliant first impression. Your room dimensions means you need to opted for a smaller screen(i.e. 92"). But I can guarantee you will not be disappointed if you do so!
If you cannot opted for a smaller screen then the Panasonic PTAE1000 is the next best projector at this price level and it will fit your screen.
Regards. Shane.
06-07-2007, 1:03 PM
#4 (permalink)
| | New Member
Thanks: Gave 2, Got 1 | Re: Themescene 80 vs Panasonic 1000e
Hi Shane
Thank you for the advise but can you confirm that using the HD80 on a screen larger than 92 inch wide will result in a degraded picture?
06-07-2007, 1:15 PM
#5 (permalink)
| | Conspicuous Member
Originally Posted by max7 Hi Shane
Thank you for the advise but can you confirm that using the HD80 on a screen larger than 92 inch wide will result in a degraded picture? | Max7
How far would the PJ mounted be from the screen ? The limit may be due to the maximum image size from a given throw i.e. to achieve a 8' wide image the PJ would need to be mounted ~ 18' from the screen.
AVI
06-07-2007, 2:27 PM
#6 (permalink)
| | New Member
Shane,
The screen will be a maximum of 16 feet away
06-07-2007, 2:28 PM
#7 (permalink)
| | Assured Advertiser
Thanks: Gave 5, Got 688 | Re: Themescene 80 vs Panasonic 1000e
IMO screensize is irrelevant here. The HD80 will offer the best picture without much stress at all. The question will be the relatively fixed installation position (no lens shift), any running noise differences, and if you suffer from rainbows. The picture though, 100% of the time will be better on the HD80.
06-07-2007, 2:30 PM
#8 (permalink)
| | Senior Member
Thanks: Gave 178, Got 212 | Re: Themescene 80 vs Panasonic 1000e Quote:
Originally Posted by Liam @ Prog AV IMO screensize is irrelevant here. The HD80 will offer the best picture without much stress at all. The question will be the relatively fixed installation position (no lens shift), any running noise differences, and if you suffer from rainbows. The picture though, 100% of the time will be better on the HD80. |
Do you have them in stock as well now Liam ?
__________________ Panasonic Plasma TH42PZ82....PJ: JVC-HD1....LumagenHDP ..Screen: Beamax High Contrast 106"...Denon 1909...Toshiba HD-E1 HD-DVD.....SKYHD (1TB HDD), Sky+ Pace V2.....Sony PS3....Nintendo Wii...Std Xbox...Remote: Harmony 885...KEF 2005.3 @ 7.1, |
06-07-2007, 2:40 PM
#9 (permalink)
| | Member
Thanks: Gave 23, Got 17 | Re: Themescene 80 vs Panasonic 1000e
How bright are the two in comparison? I plan on powering 2 screens - a 7ft white 1.0 gain and a 6ft grey 0.8 - and want something bright enough to last a good while. I had a TW1000 which, due a fault, was sent back. I was pretty impressed with it, but even with a brand new bulb it was struggling in terms of brightness in my non bat cave of a room.
If the Themescene is nice and bright when calibrated I could live with a few rainbows.
06-07-2007, 2:53 PM
#10 (permalink)
| | Assured Advertiser
Hi All
Just be in a Demo with the HD80 and one very happy customer.
As for the image degrading I feel that on a 106" screen compared to the other 1080p projectors this will still offer one of the best results you can achieve. To fit this projector in you need around 18' as a minimum distance.
As for the brightness. Haven't tried it on a grey screen but on the Beamax M Silver is plenty bright enough for me, I expect if you need the extra contrast then the HD80 will not disappoint.
Noise level. The HD80 is very quiet and does not distract in any way form the movie.
And yes we have stock.
Regards. Shane
06-07-2007, 2:54 PM
#11 (permalink)
| | Assured Advertiser
Hi Warbie
The Themescene HD80 is Brighter.
Regards. Shane
06-07-2007, 5:44 PM
#12 (permalink)
| | New Member
The panny is an exceptional machine - if the HD80 is indeed superior... in what areas does it excel ?
06-07-2007, 5:51 PM
#13 (permalink)
| | Assured Advertiser
By being a DLP machine |
06-07-2007, 6:01 PM
#14 (permalink)
| | Conspicuous Member
Originally Posted by Liam @ Prog AV By being a DLP machine  | Assuming you or your family or friends are not affected by rainbows.
AVI
06-07-2007, 6:15 PM
#15 (permalink)
| | Assured Advertiser
As I said in my previous post, the *picture quality* will go to the HD80. You must take into account other factors such as RBE, no lens shift, fan noise etc and if they might affect your specific installation.
Calibrated ANSI contrast ratio for example I think was mentioned here or on another HD80 post. Was in the 500s which is exceptional. Only a handful of other DLP machines go above this. I do not know the figure for the Panasonic, but it will be around 300 at best. The JVC HD1 is high 300s
