Why not just buy a VGA>DVI-D cable ?
Because it won't work! Surely you cannot connect analogue VGA signals via a DVI-D interface precisely because, unlike a DVI-I or DVI-A interface, it lacks the appropriate pins for analogue R,G,B, and horizontal and vertical sync (the extra five pins missing on DVI-D but present on DVI-I).
I have a Radeon 8500 and it does come with a DVI-I to DVI-I or DVI-D cable.
The problem with the new Sony projector is that they only saw fit to provide a DVI-D connector therefore, you have to connect your analogue VGA sources such as a PC via the PJ-Multi connector which means buying an SIC-HS30 cable. That was the point being made by the reviewer in the Japanese article (although this may not be that clear in the translation).
Alex.
