pro v WOW!!!!
Old 09-10-2002, 10:17 PM   #1
woody183
Posts: n/a
pro v WOW!!!!
To all who has helped.
I purchased a pro v today to use with my ae100e. The resulting picture with sky was amazing .
I am very satisfied with my setup now and would like to thank those who has given me great advice in the past .
CHEERS......
woody
Old 10-10-2002, 5:06 PM   #2
Walter mitty's Avatar
4,663, Level: 16
Points: 4,663, Level: 16 Points: 4,663, Level: 16 Points: 4,663, Level: 16
He he he hate to say this but
Told u so
Old 10-10-2002, 5:49 PM   #3
Timh's Avatar
22,934, Level: 36
Points: 22,934, Level: 36 Points: 22,934, Level: 36 Points: 22,934, Level: 36
Activity: 11.4%
Activity: 11.4% Activity: 11.4% Activity: 11.4%
Thanks: Gave 183, Got 82
Woody
Thats great new's Out of interest, what Sky connection were you using before the ProV, with the AE100?
I want one, i want one
Old 10-10-2002, 6:50 PM   #4
woody183
Posts: n/a
what sky connection?
Hi tim.
I have a grundig digibox which has s-video out. I thought with would be ok with my ae100 without the pro v. HOW WRONG! i borrowed a pro v before purchasing and was amazed at the difference. IMO if you watch a lot of sky,then it's money well spent
woody
Old 10-10-2002, 6:56 PM   #5
Timh's Avatar
22,934, Level: 36
Activity: 11.4%
http://www.avforums.com/forums/showthread.php?threadid=50223&goto=newpost
I do watch a lot of Sky, currently via s-video, using a rgb/svideo convertor from my Sony box. The colour and contrast was a great improvement over composite, but I find the screen door is still pretty bad with s-video, so i guess the ProV will have to go to the top of my shopping list for next year.
Thanks.
Old 12-10-2002, 4:59 PM   #6
8,492, Level: 22
Points: 8,492, Level: 22 Points: 8,492, Level: 22 Points: 8,492, Level: 22
Thanks: Gave 3, Got 66
Tim,
There is no way to remove screen door by feeding a different signal to the AE100. It's caused by the low-res panels. Only 'cure' is either de-focusing to hide it or watching from further away.
The improvement in picture quality you mean is to use progressive scan signal source like a PC or PS DVD player. An interlaced signal makes the horzonal lines more pronounced, progressive reduces it.
Old 12-10-2002, 5:47 PM   #7
Timh's Avatar
22,934, Level: 36
Activity: 11.4%
Jonny
I find that the screen door look's worse with s-video than componant, like you say it is even better still with progressive scan.
Old 12-10-2002, 5:53 PM   #8
8,492, Level: 22
I can't wait to try my Pro-V with the AE100.
I got the Pro-V 6 weeks ago but my AE100 has been away for repair since August.
Old 13-10-2002, 8:06 AM   #9
Hex Hex is offline
Hex's Avatar
7,067, Level: 20
Points: 7,067, Level: 20 Points: 7,067, Level: 20 Points: 7,067, Level: 20
Thanks: Gave 2, Got 0
The only problem I have with the Pro V is... well its not really a problem with the pro v more to do with the ae100
when using the pro v you cant use the "just" mode on the AE100 as its not available when using a vga source (ie the pro v)
how do you guys get round this or dont you's!?
Hex
Old 13-10-2002, 8:14 AM   #10
Timh's Avatar
22,934, Level: 36
Activity: 11.4%
Hex
Personally I would just leave it in wide mode and suffer the stretch with 4:3 material.
Jonny, give Panasonic a bell, I have the number if you need it.
Old 13-10-2002, 8:32 AM   #11
Hex Hex is offline
Hex's Avatar
7,067, Level: 20
that really annoys me though
guess I'll just have to flick between 4.3 and 16.9 when needed!
never mind
Old 13-10-2002, 10:13 AM   #12
8,492, Level: 22
On the 16th October, Sky One and Sky News will go 16:9.
All Sky Movie channels will be 16:9 by Easter 2003.
'Just' mode won't be needed for these channels.
Old 13-10-2002, 10:19 AM   #13
Hex Hex is offline
Hex's Avatar
7,067, Level: 20
SWEEET
ta for that info!
may I ask where you got it from!?
Old 13-10-2002, 10:25 AM   #14
8,492, Level: 22
www.wotsat.com
Old 13-10-2002, 10:28 AM   #15
8,492, Level: 22
Here's the quote from www.wotsat.com,
"Sky News and Sky One go widescreen this week
Sky News and Sky One are expected to begin broadcasting in 16:9 widescreen format this week. The pair intend to switch to the format at 6am on October 16, although this date could be delayed by ongoing technical tests. Sky has also said it plans to switch its film channels over to widescreen format by Easter 2003 - a move that's sure to be welcomed by film fans. [Oct 10]"
Old 13-10-2002, 10:44 AM   #16
Timh's Avatar
22,934, Level: 36
Activity: 11.4%
As Homer say's "Yahoooooooooooooo"!
Old 13-10-2002, 10:53 AM   #17
Comer's Avatar
27,692, Level: 40
Points: 27,692, Level: 40 Points: 27,692, Level: 40 Points: 27,692, Level: 40
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 19, Got 76
Please forgive my ignorance but what is a Pro V when it's at home.
Conor
Old 13-10-2002, 11:24 AM   #18
Timh's Avatar
22,934, Level: 36
Activity: 11.4%
Comer, take a look here
Old 13-10-2002, 2:48 PM   #19
Comer's Avatar
27,692, Level: 40
Activity: 0.8%
Thanks Tim
Conor
Old 13-10-2002, 7:23 PM   #20
Kramer
Posts: n/a
Hex
AFAIK, the only way to have complete control of aspect ratios using the VGA input of the AE-100 is using a HTPC.
I'm using Dscaler & a Pinnacle PCTV Rave capture card, & it's all there man
This obviously allows driving the PJ at it's native res also, so bypassing any internal scaling by the PJ.
Recently found a solution to a problem I was having, & now, IMO, I have the best possible picture using Sky/S-video/PC/Dscaler.
One happy camper
Old 14-10-2002, 8:23 AM   #21
stan_toopee
Posts: n/a
does anyone know how to reduce the RED bleeding towards the right when using Digibox to RGB converter to Pro-V to AE100.
my sky picture is pretty good, but i think it will be better if i can solve this.
thanks in advance.
Old 14-10-2002, 7:16 PM   #22
8,906, Level: 22
Points: 8,906, Level: 22 Points: 8,906, Level: 22 Points: 8,906, Level: 22
which version are you using, John Sim's or Lectropacks??
Old 15-10-2002, 6:11 AM   #23
stan_toopee
Posts: n/a
had a fiddle with the setings on the pro-v last night, and got it a bit better but it's still there.
the RGB converter is the lektropaks version
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
6 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
 Updated February 10th at 1:30am. Prices include delivery.
