Infocus SP4805 .....VGA input ?!?!
Old 13-03-2007, 7:08 PM   #1
4,505, Level: 15
Points: 4,505, Level: 15 Points: 4,505, Level: 15 Points: 4,505, Level: 15
Thanks: Gave 2, Got 0
Question Infocus SP4805 .....VGA input ?!?!
right i just bought a VGA cable for my Xbox 360 and was hoping to plug the VGA into the digital port using this adapotr because it has a stange Dvi m1-DA port on it .... http://cgi.ebay.co.uk/ws/eBayISAPI.d...4295&rd=1&rd=1
but im not getting a signal ?! is this not going to work ?!?
cheers dom
Old 13-03-2007, 7:17 PM   #2
Conspicuous Member
21,526, Level: 35
Points: 21,526, Level: 35 Points: 21,526, Level: 35 Points: 21,526, Level: 35
Activity: 23.1%
Activity: 23.1% Activity: 23.1% Activity: 23.1%
Thanks: Gave 4, Got 1,393
Re: Infocus SP4805 .....VGA input ?!?!
Nope. You infocus most likely handles DVI-D D=digital, VGA is analogue. Has it got a Component input?
Old 13-03-2007, 8:18 PM   #3
Illustrious Member
40,948, Level: 49
Points: 40,948, Level: 49 Points: 40,948, Level: 49 Points: 40,948, Level: 49
Activity: 32.2%
Activity: 32.2% Activity: 32.2% Activity: 32.2%
Thanks: Gave 277, Got 1,645
M1-DA can do both Digital and Analogue (DA).
Is there a analogue button on the PJ remote for the M1-DA connection?
Old 13-03-2007, 9:33 PM   #4
4,505, Level: 15
thats what i thought it could do both !!! no it has an auto image button but it doesnt seem to do anything lol im at a loss
Old 13-03-2007, 10:54 PM   #5
Conspicuous Member
21,526, Level: 35
Activity: 23.1%
Those adapters are for plugging into the back of a PC to change the gender from DVI to VGA, i.e. split off the analogue output, and I would guess they are not designed to work the other way round. Just found this http://www.keene.co.uk/electronics/m...?mycode=KAM1DA
Old 13-03-2007, 11:18 PM   #6
Illustrious Member
40,948, Level: 49
Activity: 32.2%
They are for Infocus PJ's and anything else with a M1-DA socket. Even though a DVI signal will work through them. They are not DVI sockets (they are longer and have different pins). It is possible to get adapters for which way you want. I have seen VGA to M1-DA on a Infocus IN72 PJ using a laptop.
Old 14-03-2007, 6:55 PM   #7
4,505, Level: 15
To Andy98765....this connector that i have bought states on the ad that its for my pj and will give me a VGA input ?!?!
the lead you link to is the one that comes with the pj ...i guess i could just use a gender bender and join my vga cable to it but i just dont see why my cable adaptor doesnt work ?!?
Old 14-03-2007, 7:13 PM   #8
7,290, Level: 20
Points: 7,290, Level: 20 Points: 7,290, Level: 20 Points: 7,290, Level: 20
Thanks: Gave 46, Got 78
I use one a similar adaptor on my 4805 from my scaler over 9m of VGA cable and it gives a great picture. Are you outputting RGB from the source?
Old 14-03-2007, 7:29 PM   #9
7,290, Level: 20
I'm sure the advice is well meant; but incorrect. Your adaptor looks OK to me. This connection on this projector doesn't take well to double adaptation either - although thats more a HDMI - DVI thing. If your x-box allows try outputting a standard computer resolution eg. 640x480 and see if it can lock to that. And don't forget the old chestnut of trying a different cable.
Old 17-03-2007, 5:57 PM   #10
4,505, Level: 15
Righty ok ive now got my vga signal coming out of my xbox into the vga y-lead and off to my pj and off to my lcd screen but when i plug in the lcd screen into the splitter both pics come on fine but it just dims the picture slightly?!?! how can i stop this from happening ?!
Old 17-03-2007, 6:04 PM   #11
7,290, Level: 20
Either find something to amplify the signal or alter the settings the 4805's menus to compensate. What was the solution to your original problem?
Old 20-03-2007, 7:02 PM   #12
4,505, Level: 15
well im not to sure really ?! the adaptor i bought just didnt work. i ended up using the lead that comes with the pj for connecting it to a pc, and just used a male to male VGA joiner and all works ok ! cheers lads...
a VGA amp...sounds expensive ?!
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
5 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
 Updated February 10th at 2:30pm. Prices include delivery.
