Hitachi PJ-TX300 LCD Projector URGENT HELP
Old 21-02-2007, 5:20 PM   #1
3,476, Level: 13
Points: 3,476, Level: 13 Points: 3,476, Level: 13 Points: 3,476, Level: 13
hi
i just recieved my Hitachi PJ-TX300 LCD Projector today from discounttv.co.uk but when testing it i found out that component only plays in blackand white without colour. is the proector faulty or is it just something i need to do on the settings???
thanks for any help
Old 21-02-2007, 5:23 PM   #2
swiftpete's Avatar
9,566, Level: 23
Points: 9,566, Level: 23 Points: 9,566, Level: 23 Points: 9,566, Level: 23
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 79, Got 241
Re: Hitachi PJ-TX300 LCD Projector URGENT HELP
My tx300 displayed in colour from component out of the box without any need for settings adjustment. Are you sure the source is ok, have you tried it with anything else?
Old 21-02-2007, 6:28 PM   #3
3,476, Level: 13
tried it with dvd and with ps2 both the same
Old 21-02-2007, 6:31 PM   #4
swiftpete's Avatar
9,566, Level: 23
Activity: 6.1%
But have you tried them with anything else that accepts component input to check they work ok through the lead you're using etc in colour?
Does sound like the projector but just to rule that out thats all.
Old 21-02-2007, 6:55 PM   #5
Nebby's Avatar
9,648, Level: 23
Points: 9,648, Level: 23 Points: 9,648, Level: 23 Points: 9,648, Level: 23
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
Thanks: Gave 15, Got 42
How did you use your dvd player the TX-300?
Did you use Scart to connect it to your display device, or have you always used component cables?
If this is the first time using component, I'd check the dvd player's settings.
Old 21-02-2007, 7:46 PM   #6
james_uk9's Avatar
7,613, Level: 20
Points: 7,613, Level: 20 Points: 7,613, Level: 20 Points: 7,613, Level: 20
Thanks: Gave 16, Got 32
I tried mine on component yesterday from x360 and a/v amp, worked fine with no messing. It sounds to me like a faulty source or a faulty cable, unless of course it's the projector itself but unlikely imo.
Old 22-02-2007, 11:33 AM   #7
StreetDragster's Avatar
5,679, Level: 17
Points: 5,679, Level: 17 Points: 5,679, Level: 17 Points: 5,679, Level: 17
Thanks: Gave 7, Got 5
Hi Sach,
You say your trying it on component, but they say you have tried it with a PS2, are you using a composite lead (Red/White/Yellow Plugs) from the PS2??
If you are, the yellow plug only needs to go into the composite port.
When i use a PS2 on mine, or an older DVD player, i have to use composite, but for new Xbox 360 i use the component plugs (Red/Blue/Green Plugs)
Any help?
Matt
Old 22-02-2007, 12:46 PM   #8
3,476, Level: 13
i did use the scart for it, this is the first time that i'm using component cables. Ill check out the settings on the DVD player and see if that will solve it. DVD player works fine when using S Video.
Originally Posted by StreetDragster View Post
Hi Sach,
Any help?
Matt
When trying it with PS" i used the red/white/yellow plugs and it came up with a black and white picture.
When i used the video connection it came up in colour. sorry for being such a nooobie but what the composite?? kinda new to all this audio visual stuff
Old 22-02-2007, 1:01 PM   #9
5,679, Level: 17
If you using the Red/White/Yellow plugs, that a composite output from the PS2. Basically, the tv signal is in the yellow plug, and the stereo sound is int he red and white plugs. So to get a working output from a PS2 you need to plug your yellow plug into the yellow 'Video' plug on the projector. Then select the the input to 'Video'.
For sound plug the red and white plugs into your reciever.
If your dvd player also has red/white/yellow plugs the same setup is needed.
If you have a component emitting source, you will have three outputs from the source, red, green and blue, and these plug into the three component inputs of the projector, and then set the projector input to 'component'
Hope that helps
Matt
Old 22-02-2007, 4:26 PM   #10
Nebby's Avatar
9,648, Level: 23
Activity: 1.2%
Sach117
I'm sure the "problem" is at the dvd player...and it's not a problem as such, so don't worry.
I helped my dad set up his projector the other day, and we hit the same stumbling block. SVHS cable produced a colour image, but component (the one with the red, blue, and green plugs) was coming out in black and white.
I went into his dvd setup menu, and tried the different picture options one at a time. I think the one called RGB Out (or something like that) worked - hey presto, a lovely colour image.
For your PS2, as StreetDragster says, all you need to plug into your projector is the yellow composite plug (it goes into the yellow socket marked video), and then select "video" on the TX300's remote to view the action.
The red and white plugs carry the sound from your PS2, and they need to go into your amp.
Let us know how you get on - us TX300 users gotta stick together!!
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.47 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
2 prices from
 £149.95 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
3 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
7 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 13th at 4:30pm. Prices include delivery.
