Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD200X
Optoma Pico
Epson EMP-TW700
Acer X110
Panasonic PT-AE3000
Optoma ES522
 More...Prices updated November 21st at 4:30pm and include delivery.
Old 12-02-2007, 11:50 PM   #1 (permalink)
sut
best connections for best picture
can someone tell me what are the best cables to get for the best picture from my skybox ( not hd ) to my projector please. as i wish to lose as little Quality as possible.
also if possible could u show me a picture of both ends of the cable as i will be getting it for ebay and they have some many diff kinds i am gettin lost with vga connection that then backs into 3 coloured connections and gold cables ect ect
thanks for any help
sut is offline   Reply With Quote
Old 13-02-2007, 5:14 PM   #2 (permalink)
Thanks: Gave 1, Got 4
Re: best connections for best picture
Is it Sky+ or normal Sky box? What projector do you have?
Generally speaking in order of preference (excluing HDMI as only SkyHD has that output) I would say...
Component (Red, Green + Blue phono connectors or possibly through a SCART connector as long as it is RGB enabled)
S-Video (4-pin round connector)
Composite (simple 2 way yellow phono connector)
Occasionally a projector will take component video, but only through a VGA port, commonly a 15-pin D-sub like the output ports on a PC. In this case you will need a cable that has the three RCA jacks on one end for the DVD player, and a 15-pin D-sub VGA connector on the other.
PH001 is offline   Reply With Quote
Old 13-02-2007, 6:00 PM   #3 (permalink)
Thanks: Gave 1, Got 8
I have found s-vid to be fine for sky (nonHD) avoid composite (single yellow plugged cable) like the plague
Critters is offline   Reply With Quote
Old 13-02-2007, 8:38 PM   #4 (permalink)
sut
it is a sky+ box and is bein connected to a benq 620p
Component (Red, Green + Blue phono connectors or possibly through a SCART connector as long as it is RGB enabled) i dont think i have these connections on the back of my skybox. also i am not sure if the scart is rgb enabled is there anyway to find out
thx
Old 13-02-2007, 8:52 PM   #5 (permalink)
Anim's Avatar
Thanks: Gave 32, Got 54
thx
Im pretty sure a full scart lead has all pins in it, some cheapo ones only have a around 6
PS3, XBox360, Wii, Marantz SR-6003 Receiver, Samsung 42" 1080p LCD + 92" Infocus In78 Projector
PSN=Anim XBOX360Tag=Anim001
Anim is offline   Reply With Quote
Old 14-02-2007, 4:54 PM   #6 (permalink)
If your projector has a SCART input then I would definitely use that. You have 2 SCART outputs on your Sky+ box but it's commonplace that only one of them is fully RGB enabled so you need to use the right one (it's usually SCART1 rather than SCART2).
Alternatively go for the S-Video as I know Sky+ has that output. Not quite as good as component but still a hell of a lot better then composite which tends to exhibit bad dot creep on PJ's
Old 15-02-2007, 4:42 PM   #7 (permalink)
DMT
Thanks: Gave 7, Got 12
"best cables to get for the best picture from my skybox ( not hd ) to my projector "
SKY - SCART cable - JS SCART/to component converter - component cable - projector
Living Room- Epson TW500 PJ Pioneer 503MXE Plasma Pio 868 DVD Pio AX4 Amp 6 x B&W VM1 Rel Q150E Sub JS Scart-Comp Sky+ Xbox360 Home Cinema (Garage)- MA GR20 MA GR10 MA GRLCR MA GRFX Pioneer AX10Ai 3 x Musical Fidelity M250 Monoblocks SVS PB12+ SMS-1 Carada 118" JVC HD1 360 PS3 EP35
DMT is offline   Reply With Quote
Old 15-02-2007, 5:10 PM   #8 (permalink)
...unless he has a SCART input on the PJ, in which case just take it in direct.
connections, picture
