projector on pc advice
Old 11-02-2007, 8:39 PM   #1
Thanks: Gave 5, Got 10
please i asked this a week ago and didnt get an answer to my problem
i can run my panasonic pt-ae900 fine on my pc using hdmi to dvi lead
but when viewing movie windows or start a dvd on the pc the proojector seems to dim up and it is annoyying
can any 1 help my graphics card is a
ati x1600xt
thanks in advance
Old 11-02-2007, 9:26 PM   #2
3,239, Level: 13
Points: 3,239, Level: 13 Points: 3,239, Level: 13 Points: 3,239, Level: 13
Thanks: Gave 10, Got 7
Re: projector on pc advice
hi
not sure I understand your issue
If when you show the desktop on your pc, it looks fine, but when you play movies, they seem dim.
Perhaps you need to see if there is a way to change the brightness/contrast of the video overlay settings. On my nvidia card, there are separate settings for desktop and video material.
Old 11-02-2007, 9:39 PM   #3
that is exactly what i mean mate
when viewing the pc using the projector
if i navigate through windows surf the web no problem nice and bright it is (well bright enough
but when viewing movies ethier downloaded 1's or dvd discs my projector goes dim
need help with this
Old 11-02-2007, 10:01 PM   #4
Stathis
Posts: n/a
Which program/player do u use to see the movies (windvd, zoom player)? Have you also set the proper resolution and frequency for your pc desktop?(you go to the ATI Catalyst control center and enable the same resolution like the one of your projector p.e 1280X720 on 50 Hz)
Old 11-02-2007, 10:20 PM   #5
mate i use any player it all the same
power dvd/windows media 11/vlc player/nero showtime
where are these settings mate and can you devulge any more info
edit ok mate tried that still the priojector dims
Old 12-02-2007, 12:09 AM   #6
7,565, Level: 20
Points: 7,565, Level: 20 Points: 7,565, Level: 20 Points: 7,565, Level: 20
Thanks: Gave 103, Got 54
maybe you need different settings on your projector for watching video, like turning up the gamma or disabling the iris, etc.
Old 12-02-2007, 9:15 AM   #7
Anim's Avatar
10,886, Level: 25
Points: 10,886, Level: 25 Points: 10,886, Level: 25 Points: 10,886, Level: 25
Thanks: Gave 48, Got 60
It sounds like an overlay problem as it only happens on video (which uses overlay). Find the graphic card overlay settings and tune the gamma / brightness.
Old 12-02-2007, 10:47 AM   #8
thanks mate but i cant find anything like that
thing is the whole desktop will dim not just the video window
Old 12-02-2007, 2:25 PM   #9
Anim's Avatar
10,886, Level: 25
To see if its an overlay issue try this
1. Open Media Player. On the Tools menu, click Options. This will open the Options dialog box.
2. In the Options dialog box, click the Performance tab.
3. In the Video acceleration area, click the Advanced button.
4. In the Video Acceleration Settings dialog box, clear the check box for Use Overlays. (Its on video and DVD so play around)
5. Select OK and then OK again to close the dialog box.
6. Playback the video.
Here is a guide by ATI on how to setup HDTV using your drivers (there is mention here about setting brightness)
http://ati.amd.com/products/catalyst...etup_Guide.pdf
Also check out ATI Tray Tools which has access to the theatre mode overlay
http://www.guru3d.com/article/atitraytools/189/
There are some good FAQ Tech docs at
http://support.ati.com/ics/support/d...asp?deptID=894
You can also submit a ticket there to log your problem
Anim
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
5 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
 Updated February 10th at 11:30am. Prices include delivery.
