Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
InFocus Play Big X9
Acer X110
Optoma HD200X
Optoma HD20
Panasonic PT-AE3000
Optoma Pico
 More...Prices updated November 25th at 5:30am and include delivery.
Old 17-01-2007, 3:32 PM   #1 (permalink)
MrFlicks
Posts: n/a
Sharp M20X - HD or not?
I want to upgrade the dvd player we use to either HD or upscaling to 1080. Our Sharp M20X's are XGA resolution.
I have heard two different dealers one says no point in getting HD or Upscaler as XGA is limited in its resolution/lines. another says that it would be Ok and there would be significant improvement in picture.
The manual for the M20 says it will take 1080i.
What is true, as I don't really have a clue!
Ian
Old 17-01-2007, 3:44 PM   #2 (permalink)
Advertiser
Thanks: Gave 19, Got 52
Re: Sharp M20X - HD or not?
What DVD player are you using at the moment and how are you connecting it? Bear in mind that the M20 can accept component but only via adaptors into it's DVI port.
Ken Davies
Ivojo Multimedia Ltd. - Projectors, Projection screens and AV systems.
http://interactive-av.co.uk
http://twitter.com/ivojo
Ivojo is offline   Reply With Quote
Old 17-01-2007, 3:45 PM   #3 (permalink)
MrFlicks
Posts: n/a
we use Arcam Diva 88's, component out into DVI input.
thanks for reply.
ian
Old 17-01-2007, 3:50 PM   #4 (permalink)
Advertiser
I don't think you're going to get much better than the Arcams. You may get a marginal improvement using a scaler/upscaling player but to get any real improvement I think you'll need to change the projector to a HDReady one.
Ken Davies
Old 17-01-2007, 3:52 PM   #5 (permalink)
MrFlicks
Posts: n/a
Thanks Ken. At least it is good to know that we have done ok so far. We run 9 sets of Arcams/M20x's. I do have some grant money to buy a new projector and Dvd player and i will be looking around the site to pick up some information.
cheers
ian
flicks in the sticks
m20x, sharp
