Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
InFocus Play Big X9
Acer X110
Optoma HD200X
Optoma HD20
Optoma HD700X
Panasonic PT-AE3000
 More...Prices updated November 24th at 6:30pm and include delivery.
Old 20-08-2002, 10:03 PM   #1 (permalink)
darren7
Posts: n/a
"SONY VW11HT owners CABLE CHOICE"
Hi there
I have looked at some old posts and I’m a bit confused.
I would like to run my cables directly to the projector, 5-6 metres.
Out of the skybox for RGB (scart). I would like some good quality cables, I have read some post that people were getting cross-hatching and thing like that; obviously I would want to avoid this.
As the cost of cables can be quite high I want to get it right
Also the same for the component video cables.
Are you running the cables separate and are the special connections?
What quality are you people getting from RGB into the vw11ht, could you also advise on makes, and the connections that you are using
Thanks for all your previous help
Darren
Old 21-08-2002, 7:32 AM   #2 (permalink)
Thanks: Gave 15, Got 35
Well I've got a VW10HT, so it almost counts, and I've found for component and s-video that Lektropaks pro series seems pretty good, compared 10M lenghts of each with some hiqh quality shorter stuff like Monster and chord, with naff all difference. The component cables code is PAL4 if your interested.
slingshot is offline   Reply With Quote
Old 21-08-2002, 7:45 AM   #3 (permalink)
Super Moderator
Thanks: Gave 465, Got 946
I confirm the above.
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
Old 21-08-2002, 12:52 PM   #4 (permalink)
darren7
Posts: n/a
how many
do I run 3 Component, and 3 for RGB? this is 6
is this correct or do I need to run more or less.
or is it 4 for the RGB
I want good quality cables though. qed? , cord? van de?
Darren
Old 21-08-2002, 1:29 PM   #5 (permalink)
Yep 3 for component, i didn't bother with RGB, but if your going for RGB you'll probably need 4, I vaguely remember someone on the board having to use a composite output as a sync for RGB (might be wrong though).
If you going to be using a computer input at anytime you'll probably want to put 5 in for RGB and separate H and V synch's (at least that's what I think they're for).
Does that make sense ? Someone will probably correct me if I'm wrong about any of the above.
Old 22-08-2002, 7:50 AM   #6 (permalink)
Super Moderator
Re: how many
At the risk of repeating...... Lektropacks
Nigel
Old 22-08-2002, 11:21 AM   #7 (permalink)
darren7
Posts: n/a
yes I but how good are the Lektropacks RGB cables
Darren
Old 22-08-2002, 12:46 PM   #8 (permalink)
Super Moderator
I use a Lektropacks 10m 3xRCA > 3xRCA cable for component which cost about £75. It is well constructed and performs flawlessly. IMHO there is no point, other than psychological satisfaction, in spending more.
Nigel
