Bright spot on PJ-TX200
Old 24-11-2006, 1:14 PM   #1
4,085, Level: 15
Points: 4,085, Level: 15 Points: 4,085, Level: 15 Points: 4,085, Level: 15
My TX200 started today showing a round brighter spot, specifically visible with darker scenes.
Is this a blob of dust, or is something wrong with the LCD panel?
Old 24-11-2006, 11:52 PM   #2
kurtz's Avatar
3,183, Level: 13
Points: 3,183, Level: 13 Points: 3,183, Level: 13 Points: 3,183, Level: 13
Thanks: Gave 24, Got 23
Re: Bright spot on PJ-TX200
Sounds like it could be dust - if it was a panel fault then the spot would have a coloured hue. LCD uses 3 colour panels so if one of them was flakey then you'd see the other two colours mixed together.
Here's a link to a similar problem on a TX200.
Old 25-11-2006, 11:58 AM   #3
3,174, Level: 13
Points: 3,174, Level: 13 Points: 3,174, Level: 13 Points: 3,174, Level: 13
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 3, Got 23
I had the same problem,always visible on dark scenes or black bars.Curiously it wasnt visible on the black pattern in the Colour Uniformity menu.I dont know the reason,i sent my projector back to Hitachi(there were other issues with it as well) and i am still waiting for it:almost six weeks now
Old 27-11-2006, 8:44 AM   #4
AV Nik's Avatar
4,975, Level: 16
Points: 4,975, Level: 16 Points: 4,975, Level: 16 Points: 4,975, Level: 16
Thanks: Gave 45, Got 106
Hi eric1403,
What screen surface are you using?
This is a common problem with High Gain screens but also, some lamps, after 1000 hours or more (sometimes earlier), can receive burns (white bleach) within the High Pressure (gas part/bubble) part of the bulb. This usually happens when the PJ is switched off without allowing it to cool down first.
Always switch the PJ off by the menu. Allow the lamp and PJ to be cooled down by the fan before switching off the mains supply to the PJ.
If your lamp shows faults within the manufacturers warranty period, Don't hesitate, call the supplier or contact the manufacturer and report it. Usually, they will offer a replacement but, some suppliers have stringent test procedures and if your lamp shows signs of abuse like 'switching off power before cooling or burning at the wrong angle', they could void that warranty.
Hope this helps?
AV Nik
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
5 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
 Updated February 10th at 12:30pm. Prices include delivery.
