Decision on which projector, help required
Old 22-11-2006, 10:12 PM   #1
747340
Posts: n/a
Please dont knock me down in flames I found this site through Google and i thought it was the best place to try and get some help
I have a spare room in my house and i want to convert it to a games room with NTL Cable TV and a ceiling mounted projector for the children
OK I currently have the NTL Cable box installed in that room but...
I obviously need a sound system to play the cable box through and I need a projector
What do i need to buy what do i need to make sure each unit has so it all connects
I presume the cable TV goes to a Home Cinema system,Do you recommend a Kit? and then something comes out of this to the projector.
I am scared of buying the wrong units that wont or are not compatable
Could anyone please suggest a good projector reasonable in value that i could purchase
Does the projector have to have a certain wire connection ie scart or something to join to the Home Cinema system
Any any help would be helpful please
Old 25-11-2006, 10:07 PM   #2
EViLDONKEY's Avatar
5,348, Level: 17
Points: 5,348, Level: 17 Points: 5,348, Level: 17 Points: 5,348, Level: 17
Thanks: Gave 73, Got 36
Re: Home cinema help
Hi. to start the proceedings do you have a budget for the project?
747340 (26-11-2006)
Old 26-11-2006, 7:42 PM   #3
747340
Posts: n/a
First of all thank you for helping me
I have done some resarch and i thought a good projector to get would be an Infocus In72 as it has a Component video conection and i was also going to buy a Samsung HTTQ25 Home Cinema as it would appear i could connect the Home Cinema to the projector through a Component connection and connect the NTL box to the Home Cimnema through a scart lead.
I hope i am correct
What do you think about this equipment or could you recommend something else
Old 27-11-2006, 9:43 AM   #4
inzaman's Avatar
22,352, Level: 36
Points: 22,352, Level: 36 Points: 22,352, Level: 36 Points: 22,352, Level: 36
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 126, Got 543
Moved to projectors
Old 27-11-2006, 9:55 AM   #5
Illustrious Member
Pecker's Avatar
43,925, Level: 51
Points: 43,925, Level: 51 Points: 43,925, Level: 51 Points: 43,925, Level: 51
Activity: 20.5%
Activity: 20.5% Activity: 20.5% Activity: 20.5%
Thanks: Gave 2,682, Got 1,886
Re: Decision on which projector, help required
The In72 is great, but you could get an Optoma HD70 for not too much more which is 720p High Definition. This will 'future proof' you against HD, which NTL is bringing in soonb, as well as future HD disc formats.
If your kids play games, then both the XBOX 360 and the upcoming PlayStation 3 have High Definition output.
For sound may I recommend the Sony HTSS1000 - available from Emire Direct at only £215. It has HDMI switching, so you could put 2 sources into that via HDMI, then that into the projector via HDMI + 1 extra source into the projector via Component.
If you have an XBOX 360 or PS3 that'll act as a decent HD disc player.
Steve W
Old 27-11-2006, 10:13 AM   #6
d_a_v_e's Avatar
4,514, Level: 15
Points: 4,514, Level: 15 Points: 4,514, Level: 15 Points: 4,514, Level: 15
Couldn't agree more HD70 looks like a great deal from a reputable manufacture and 720p HD into the bargain. My view (fwiw):
Top budget projectors (480p): Infocus IN72, Optoma H27, BenQ W100
Top HD projectors (720p): Sanyo PLV-Z5, Optoma HD70, Mitsi HD1000, Panasonic AE700.
There are some great deals around on the Sanyo PLV-Z4 which has been superceded by the Z5. The Z4 is a great HD LCD projector so worth considering if you can still get hold of one.
Also consider replacement lamp prices. The Optoma projectors generally win out here, as the others will probably be over £200. (Although there were some Z4's knocking about with a free lamp offer)
Hope this helps,
Old 27-11-2006, 10:13 AM   #7
Jammyb's Avatar
8,297, Level: 21
Points: 8,297, Level: 21 Points: 8,297, Level: 21 Points: 8,297, Level: 21
Activity: 26.9%
Activity: 26.9% Activity: 26.9% Activity: 26.9%
Thanks: Gave 47, Got 321
The BenQ W100 has virtually the same spec and performance as the IN72 but is available for under £400 and has cheaper replacement bulbs.
Old 01-12-2006, 11:24 PM   #8
747340
Posts: n/a
Please can you help me
I have now purchased my IN72 ITS FANTASTIC
My NTL box is Scart
What cable do i need to connect the NTL to a Home Cinema which then connects to the projector i am stuck on the cables needed.
If i buy the Samsung HTTQ25 home cinema what cable do i use to connect the home cinema to the IN72
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
5 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 10th at 11:30pm. Prices include delivery.
