Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > Projectors
Latest popular product pricesPowered by
Optoma HD20
Optoma HD200X
Sanyo PLV-Z700
Optoma ES522
Optoma HD20
Optoma HD200X
Sanyo PLV-Z700
Optoma ES522
Acer X110
Epson EH-TW2900
Optoma HD65
Toshiba TDP-S25U
Benq MP727
Epson EH-TW3500
 More...Prices updated March 19th at 10:30pm and include delivery.
Thread Thread Starter Forum Replies Last Post
Panasonic AX100 impressions and screenshots gandley Projectors 544 24-07-2009 4:06 PM
Panasonic PT-AX100 + Cable help rodpat Projectors 2 25-10-2006 5:06 PM
Panasonic AX100 Convergence Issues Davestan Projectors 2 21-10-2006 3:15 PM
Optoma Themescene HD72 GreenEagle Projectors 8 16-02-2006 11:56 PM
ThemeScene H72/HD72 spec announced Liam @ Prog AV Projectors 18 08-12-2005 3:17 PM
Old 04-11-2006, 7:42 PM   #1 (permalink)
Themescene HD72 or Panasonic pt-ax100
well the title says it all "Themescene HD72 or Panasonic pt-ax100"
both are around the same price now ,want to use on shelf just behind head so low noise from fan , also about 100" image from 10.5 ft .
any help much appreciated
rab4169 is offline   Reply With Quote
Old 04-11-2006, 7:49 PM   #2 (permalink)
cyberheater's Avatar
Thanks: Gave 35, Got 129
Re: Themescene HD72 or Panasonic pt-ax100
The HD72 is the one to go for if your "shelf just behind head" is at least 7 foot off the ground and you invert the projector due to the fixed lens offset. Otherwise get the AX100 and it will comfortably sit on a shelf at normal height due to it's lens shift function.
Next...
You can stuff LCD. It's high def DLP all the way for me
cyberheater is offline   Reply With Quote
Old 05-11-2006, 10:42 AM   #3 (permalink)
Zag
Zag's Avatar
Thanks: Gave 7, Got 46
The correct answer to that question is never that easy..
What about screen gain, viewing environment, levels of light control, sensitivity to rainbows the list goes on..
If you are sensitive to rainbows and perhaps want to view with a bit of ambient light the AX100 light cannon may be a better option than the HD72.
The HD72 will deliver a better picture though in a light controlled room with dark walls no question, but don't also dismiss projectors like the new Sanyo Z5 which may fit your requirements even better.
Zag is offline   Reply With Quote
Old 05-11-2006, 12:45 PM   #4 (permalink)
jamieuk23's Avatar
Thanks: Gave 184, Got 29
100" image from 10.5 ft = You wont get that big of a picture at that short distance with the HD72. I am around 12.5ft and just get around 92"
not sure about the other PJ you mentioned
jamieuk23 is offline   Reply With Quote
Old 05-11-2006, 11:58 PM   #5 (permalink)
thanks ,looks like panasonic
robert
Old 06-11-2006, 9:20 AM   #6 (permalink)
Thanks: Gave 21, Got 9
Had both of these and the hd72i blows the 100 out of the water better contrast better black a lot better black more 3d, if rainbow is not a problem get the hd72i,don.t worry about the offsets i have a 7ft 6 ceiling and have it set up with no problems its not as bad as people make out
patt is offline   Reply With Quote
Old 06-11-2006, 9:46 AM   #7 (permalink)
Conspicuous Member
Pecker's Avatar
Thanks: Gave 1,736, Got 1,208
Instead of getting the 72i you could wait for the 73.
It's due out very soon (before Christmas?). The US specs make it look better than the 72i, but at pretty much the same price.
Steve W
Pecker is offline   Reply With Quote
hd72, panasonic, ptax100, themescene
Copyright © 2000-2010 M2N E. & O. E.
