My head hurts.Which projector TX300 . Z5 . HS60 .
Old 25-10-2006, 9:50 PM   #1
GARYROSSO
Posts: n/a
Can't decide between PJTX300 . Z5 . HS60.
Any info would be much appreciated as i'm ready to buy.
Would prefer a pj that works well in ambient light.
Thank's in advance.
Gary
Old 25-10-2006, 9:52 PM   #2
9,918, Level: 23
Points: 9,918, Level: 23 Points: 9,918, Level: 23 Points: 9,918, Level: 23
Activity: 8.0%
Activity: 8.0% Activity: 8.0% Activity: 8.0%
Thanks: Gave 3, Got 54
Re: My head hurts.Which projector TX300 . Z5 . HS60 .
get a panasonic AE1000
GARYROSSO (25-10-2006)
Old 25-10-2006, 10:01 PM   #3
GARYROSSO
Posts: n/a
Just checked the price of the panasonic AE1000.Expected to be around 2200 so it's a bit too expensive for me.
Old 25-10-2006, 10:19 PM   #4
PeteIvy's Avatar
4,799, Level: 16
Points: 4,799, Level: 16 Points: 4,799, Level: 16 Points: 4,799, Level: 16
Thanks: Gave 44, Got 49
Sorry. Double post!
Old 25-10-2006, 10:20 PM   #5
PeteIvy's Avatar
4,799, Level: 16
Get the AX-100 instead. Got mine for £999 delivered . Truly blown away and I upgraded from an AE700
See gandley's post for a great review!
Pete
Old 25-10-2006, 10:29 PM   #6
9,918, Level: 23
Activity: 8.0%
Thats funny i had no idea there WAS a panasonic AE1000
I meant the AX-100 for abt £1K
Old 25-10-2006, 11:34 PM   #7
swiftpete's Avatar
9,551, Level: 23
Points: 9,551, Level: 23 Points: 9,551, Level: 23 Points: 9,551, Level: 23
Activity: 5.7%
Activity: 5.7% Activity: 5.7% Activity: 5.7%
Thanks: Gave 78, Got 240
If its any help I've just got the tx300 and set it up today with a screen. It looks absolutely amazing!
Old 26-10-2006, 2:15 PM   #8
GARYROSSO
Posts: n/a
Cheers.
I can get the tx300 with free screen or the hs60 both for £1000.
Still don't know which one to go for.
Old 26-10-2006, 3:44 PM   #9
Anim's Avatar
10,886, Level: 25
Points: 10,886, Level: 25 Points: 10,886, Level: 25 Points: 10,886, Level: 25
Thanks: Gave 48, Got 60
From reading peoples opinions who have the HS60...it works best in a light controlled room. whereas the Panny Ax can be used in a room with some light.
The HS60 is older than the other models you mention too.
I would look at the Panny AX personally. Sounds an impresive all rounder to me.
EDIT: The actual best solution for you is to demo the units at one of the retailers like Discount TV. You might find you prefer one picture over another for different reasons.
Anim
Old 26-10-2006, 3:52 PM   #10
Darkstar_surfer's Avatar
7,700, Level: 20
Points: 7,700, Level: 20 Points: 7,700, Level: 20 Points: 7,700, Level: 20
Activity: 6.4%
Activity: 6.4% Activity: 6.4% Activity: 6.4%
Thanks: Gave 37, Got 81
The TX300 appears to be last years model with a paint job. The AX100 is a light year ahead in performance and almost the same price. I was told that if I bought a TX200 and did not see a AX100 I would not miss the improvements. But I would always know I did not buy the best I could afford.
Yes the TX300 looks good, but in a black room do you care.
Old 31-10-2006, 4:28 PM   #11
GARYROSSO
Posts: n/a
Smile Re: My head hurts.Which projector TX300 . Z5 . HS60 .
Probably go for the ax100 as the extra light output is a geat bonus.
Old 31-10-2006, 10:54 PM   #12
9,705, Level: 23
Points: 9,705, Level: 23 Points: 9,705, Level: 23 Points: 9,705, Level: 23
Thanks: Gave 0, Got 7
well I think both will suit your needs fine...
If you can get em one next to the other then DO it and decide... the choice is personal. If you cannot do it, both will be amazing for you, but NEVER get them close if you have the chance... what if you prove wrong? hehe...
every decent projector is fabulous since it plays alone at home...
I am not sure if i would go for the newest models... but if you can afford it... why not have the latest specs...
Old 01-11-2006, 12:21 PM   #13
4,321, Level: 15
Points: 4,321, Level: 15 Points: 4,321, Level: 15 Points: 4,321, Level: 15
Thanks: Gave 1, Got 4
I personally have decided to go with a Z5 instead of the ax100 (waiting for stock at the moment).
The review on Projector Central comparing the Z5 with the ax100 basically said that the Z5 has the slightly better image, the ax100 is brighter (personally I suspect there isn't a lot between them image-wise, and I don't need the extra brightness). The Z5 has better connectivity with 2 HDMI and 2 component inputs (although most people will use some form of video switching to avoid running too many cables).
The z5 does cost a little bit more than the ax100, but has a three year warranty and the UK-supplied ones come with a free lamp voucher. This combined with Panasonic's reputation for poor service on projectors is really what made me choose the Z5.
When my Z5 arrives I will post some comments on how I get on.
Old 01-11-2006, 12:44 PM   #14
img img is offline
3,242, Level: 13
Points: 3,242, Level: 13 Points: 3,242, Level: 13 Points: 3,242, Level: 13
why did you rule out the tx300.
seen the tx300 for 900 and the panasonic for 980 now
Old 01-11-2006, 1:36 PM   #15
Nebby's Avatar
9,648, Level: 23
Points: 9,648, Level: 23 Points: 9,648, Level: 23 Points: 9,648, Level: 23
Activity: 1.2%
Activity: 1.2% Activity: 1.2% Activity: 1.2%
Thanks: Gave 15, Got 42
I'm loving my tx-300!!!
Old 01-11-2006, 3:43 PM   #16
cyberheater's Avatar
17,620, Level: 32
Points: 17,620, Level: 32 Points: 17,620, Level: 32 Points: 17,620, Level: 32
Thanks: Gave 41, Got 153
Maybe because it's basically a TX200 with a new paint job. The performance of the TX300 and TX200 are the same.
Old 01-11-2006, 5:16 PM   #17
swiftpete's Avatar
9,551, Level: 23
Activity: 5.7%
Yeah but it looks great! For me the free screen that i got with the tx300 helped a lot too. I'm no expert but i'm well chuffed with mine and everyone that's seen it says how great it looks. In fact 2 of them have decided to get them themselves now.
Old 01-11-2006, 10:48 PM   #18
lbt lbt is offline
4,144, Level: 15
Points: 4,144, Level: 15 Points: 4,144, Level: 15 Points: 4,144, Level: 15
Thanks: Gave 4, Got 0
Me too - I ordered mine a couple of days ago for almost exactly the same reasons.
It's probably just a coincidence we have the same surname
Old 02-11-2006, 12:43 PM   #19
Location: SBC (Swedish Born Chinese)/lived in UK since 96, Colchester since 02
8,490, Level: 22
Points: 8,490, Level: 22 Points: 8,490, Level: 22 Points: 8,490, Level: 22
Thanks: Gave 21, Got 30
Anim
Agree with Anim, once discounttv receives the Z5, they will stock all 4 major lcd pj's.
wasabi
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
5 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 11th at 1:30am. Prices include delivery.
