Originally Posted by Darkstar_surfer Ok, switching to stupid mode - How does a projector project black. |
Ideally it doesn't , black is absence of light. The visible level of black will be down to how much light the projector can block from the black areas of the image ( unlikley to be zero on any projector even a properly setup CRT) and what the ambient light levels in the room are turn the lights out draw the curtains and your black is never going to get blacker than the screen appears.
If you have a bright enough white level relative to your black level your eyes will percieve the image as having adequate contrast even if the blacks are slightly illuminated. Imagery with low contrast ( dark scenes) might look a bit washed out on projectors with a high black level though. CRT doesn't need to be particularly bright as it has very low black levels , LCD which has comparatively light blacks and needs quite a high white point to display a visually adequate contrast range.
