Help! Connecting a dvd player to a data projector via vga
Old 24-09-2006, 8:03 PM   #1
MissL
Posts: n/a
Smile Help! Connecting a dvd player to a data projector via vga
I have a digital projector in my classroom and want to hook it up to a dvd player. The only problem is that it is mounted to the (very high) ceiling and only the vga plug that goes into the back of my computer is available.
Does anybody have any suggestions of what lead would allow me to connect the dvd player to the vga lead? I can connect speakers, so that's not a problem. I would love to play dvds through the computer, but the IT bods can't install the software!
Many thanks!
Old 26-09-2006, 6:57 AM   #2
Ianfromnotts's Avatar
6,340, Level: 18
Points: 6,340, Level: 18 Points: 6,340, Level: 18 Points: 6,340, Level: 18
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 12, Got 169
Re: Help! Connecting a dvd player to a data projector via vga
check out outputs are available on the DVD and what signals the projector will accept over the VGA input. Then key the info in to google eg
Component to VGA lead (if the projector accepts component and the DVD outputs
Scart RGB to VGA lead ( if the DVD has an RGB enabled scart and the Projector accepts RGB )
Then check the cable has the right male/female VGA connection to link to your lead
Old 26-09-2006, 8:04 AM   #3
4,900, Level: 16
Points: 4,900, Level: 16 Points: 4,900, Level: 16 Points: 4,900, Level: 16
Thanks: Gave 17, Got 4
The most obvious answer is to insist that your IT guys install some DVD playback software on your computer.- it shouldn't be difficult. PowerDVD and WinDVD are the most popular and can be bought for less than the price of any lead.
Failing that if your PC is too old, your projector should have a yellow "phono" type connector which accepts a composite video input. You would need a lead that was a scart socket at one end to a "composite video + Left/Right Audio" on the other end. The quality from this connection would make a home cinema enthusiast cringe, but for classroom use we find it more than adequate (I am an IT engineer who works in primary schools.) the red and white connections go to the sound system and the yellow connection goes to the projector.
http://www.maplin.co.uk/module.aspx?...28102&doy=26m9
If the projector is too high up you can always extend the yellow wire with this:
http://www.maplin.co.uk/module.aspx?...=9664&doy=26m9
Converting a scart or composite signal to VGA is not really a good option as any device which does this is likely to be both expensive and not very effective
Hope this helps you
Dave
Old 26-09-2006, 5:34 PM   #4
MissL
Posts: n/a
Thank you very much for your responses - I'm going to print them and show the IT chaps how helpful complete strangers can be!
Thanks again!
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
3 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
7 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 11th at 1:30pm. Prices include delivery.
