Formula for dvd-playing happiness :
Set the resolution of the PC to the native resolution of your projector, in the case of the TX200, 1280x720;
In Powerdvd, go into Configuration/Video and tick the box for Hardware Acceleration; set the picture settings to "Original";
In Configuration/Audio, set powerdvd to output sound via SPDIF;
Connect the PC to the Projector using a VGA or DVI cable;
Set the audio software that controls your soundcard to output a digital SPDIF signal;
Connect your soundcard to your AV receiver Digital-In;
Set your projector Source to PC Input;
If there's an option in the projector's menu to "synch" with a PC input, use it.
Sit back and watch............... I have yet to see a dvd player that will match a PC 1:1 pixel matched with a projector. From what I've read, various upscaling dvd players can come close enough, but I've yet to read of one that doesn't have firmware glitches of one kind or another.
Insofar as the other benefits of HCPC are concerned, try BBC HD and free-to-air satellite with full PVR, full HD movies, tv programs the day after they're broadcast in the States.......... Mmmmm...
Just for the record, Theatertek2, which uses nVidia Purevideo decoder (and FDDshow postprocessing, with Avisynth and Limitedsharpen if you like) is probably the zenith of dvd playing software. I'm not a huge fan of Theatertek, but have run a setup of Zoomplayer, nVidia Purevideo dvd decoder, FDDshow with Limitedsharpen running through an nVidia 6600 graphics card and it is very revealing, although it takes a little work to set up. It helps if you're familiar with that kind of software, if you're not Powerdvd will do perfectly well.
S.
