Originally Posted by ozz1983 Should I set the lamp power on low and fan control on high (it says in the manual "only for altitudes of over 400m) to increase lamp life? |
I've heard that this can also shorten it... would like a definitive answer myself to that one.
Originally Posted by ozz1983 My image doesnt seem straight, the right hand side is streched so it is taller on the right than the left. Is there a way I can fix this? |
The PJ ideally needs to be situated towards the top of the screen and at the exact centre.
If you put it at an angle you get the effect you describe. This can be fixed in the PJ (keystone correction) but it makes picture quality worse - it's better to move the PJ so it doesn't occur.
The lens correction helps with positioning if you can't get the PJ central (that doesn't affect PQ).
Originally Posted by ozz1983 Do I have to set it to hd when using an hd source or is it automatic. I am using an xbox360 and have set it to 1080i in the xbox dashboard. |
It's automatic - the menu will display the format it's receiving.
Originally Posted by ozz1983 Also any advice on picture settings as it seems a little blurry? |
Focus is quite sensitive - find something with sharp detail (eg. the Xbox live dashboard) and move the focus until it's as sharp as you can get it.
Originally Posted by ozz1983 I am also running my laptop through it with a s-video cable and the quality is watchable but pretty poor. If you can help with this too, would be good (have a nvidia Geforce go 5100 card and cloned the display) |
You need to use powerstrip to change your PC mode to 1280x720, then switch overscan off in the PJ. That should give you a 1:1 mapping - PC output looks outstanding when it's setup.
If you have a VGA->VGA cable it'll give a better picture than svideo.
