How do I get a HDMI signal over 12 metres?
Old 27-06-2006, 12:19 PM   #1
4,107, Level: 15
Points: 4,107, Level: 15 Points: 4,107, Level: 15 Points: 4,107, Level: 15
Thanks: Gave 8, Got 1
Hi can any one help?
I have a denon DVD-1920 which is connected to Infocus IN76. At the moment the dvd player is sitting next to the pj and connected via a 1 metre hdmi cable. The pictures are absolutly great.
I also have a sky + box which is setting on the other side a long room (7m) and that is connected via a set of coax componet video. The pictures are ok.
I am now looking to get Sky HD and also want to move my DVD next to the rest of my kit across the room, which means somehow i need to get a high quality signal over 12 metres (due to routing the cable).
I borrowed a 15m HDMI cable and tried that with my DVD and that just did not work, not a peep.
Any one else tried something similar? help much apperciated - thks
Old 27-06-2006, 12:30 PM   #2
7,634, Level: 20
Points: 7,634, Level: 20 Points: 7,634, Level: 20 Points: 7,634, Level: 20
Thanks: Gave 11, Got 11
Runco do a cable which will run over that distance but it is major bucks Its called the livelink 50
hosh (27-06-2006)
Old 27-06-2006, 12:40 PM   #3
sniffer66's Avatar
8,372, Level: 21
Points: 8,372, Level: 21 Points: 8,372, Level: 21 Points: 8,372, Level: 21
Activity: 37.9%
Activity: 37.9% Activity: 37.9% Activity: 37.9%
Thanks: Gave 523, Got 603
I run a 15m Extra Long Lindy DVI-D cable between Sky/DVD and PJ. I know a few others use this cable on here also. Approx £50
Just put an HDMI/DVI adapter (also from Lindy) at the end you need hdmi
Never had a hint of signal loss. sparklies etc.
Its a very heavy duty cable and an absolute bitch to get around corners inside conduit tho
www.lindy.co.uk
Personally Im going to go component from SKY HD to PJ when it arrives next month. At least until theyve ironed out the HDCP issues. Also component should have less probs at those lengths
Old 27-06-2006, 12:48 PM   #4
4,107, Level: 15
Thanks for that info,
I thought that component is not as good as HDMI ?
Old 27-06-2006, 12:54 PM   #5
10,489, Level: 24
Points: 10,489, Level: 24 Points: 10,489, Level: 24 Points: 10,489, Level: 24
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 5, Got 248
12 metres is quite possible if the cable is made well... 15 metres is about the limit without using repeaters AFAIK.
Try k1connectivity
hosh (27-06-2006)
Old 27-06-2006, 1:20 PM   #6
sniffer66's Avatar
8,372, Level: 21
Activity: 37.9%
You'll find plenty of debate on that subject if you search the forums. I've tried both from a scaler with good quality leads and couldnt tell the difference in most cases ! HDMI and DVI over 7.5 m are prone to problems anyway, unless you spend bigger money
Old 27-06-2006, 1:37 PM   #7
4,107, Level: 15
yep lots out there and its quite confusing, I have a compent set up already so i'll try that from the DVD and see if i can tell the difference.
Old 27-06-2006, 2:33 PM   #8
3,633, Level: 14
Points: 3,633, Level: 14 Points: 3,633, Level: 14 Points: 3,633, Level: 14
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 5, Got 21
If your looking for another idea, try an HDMI cat5 extender. Sends up to 1080p 150ft.
http://www.gefen.com/kvm/product.jsp?prod_id=2225
hosh (27-06-2006)
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
5 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 11th at 4:30am. Prices include delivery.
