Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > Projectors
Latest popular product pricesPowered by
Optoma HD20
Optoma HD200X
Sanyo PLV-Z700
Optoma ES522
Optoma HD20
Optoma HD200X
Sanyo PLV-Z700
Optoma ES522
Acer X110
Epson EH-TW2900
Optoma HD65
Toshiba TDP-S25U
Benq MP727
Epson EH-TW3500
 More...Prices updated March 20th at 3:30am and include delivery.
Old 11-06-2006, 8:04 PM   #1 (permalink)
nickyjgordon
Posts: n/a
horizontal keystone, what is it?
i notice in many product descriptions projectors having horizontal keystone and people wanting it when buying a projector, what is horizontal keystone and should i be looking for it when purchasing a projector?
Old 11-06-2006, 8:10 PM   #2 (permalink)
geewhizz's Avatar
Thanks: Gave 140, Got 61
Keystone Correction
'Keystoning' is the name given to the effect on the projected image when the projector sits below or above the centre of the screen. Keystone correction counteracts this effect by digitally compressing the image at the bottom or top, resulting in a squarer, more professional image.
See Here
for more info
HD-DVD
DVD'S
geewhizz is offline   Reply With Quote
Old 11-06-2006, 8:31 PM   #3 (permalink)
Keystone
Hi its always nice to have horizontal and vertical keystone - but for emergency setput ups only. Why, because otherwise you loose resolution! If you can, when you are seting up the projector, set all keystones to 0, correctly position the projector to the screen. A quick test to show you what I mean by lost resolutuon:
Put on test disc (Joe kane or whatever) with needle pulse display, keystones zero, now step the keystone up or down - see what i mean?!
cinesom is offline   Reply With Quote
Old 11-06-2006, 8:35 PM   #4 (permalink)
ELV
Thanks: Gave 5, Got 12
It's the way the pj compensates if it's not on the same horizontal plane as the screen, it would be bigger on one side than the other,
so to get round this the pj lets you squre it up making the image square again, vertical keystone is more common but with many pj's mow having lens shift the need for horizontal keystone has lessened, it's better if you can get away with not using it at all, ie having the pj dead square with the screen as there is slight image loss when it's used to extremes, if you are gont to have bother sighting your pj with the screen then it would be handy,if not then it's not realy needed, but i would get one with lens shift if possible.
PSN ELVH
ELV is offline   Reply With Quote
horizontal, keystone
Copyright © 2000-2010 M2N E. & O. E.
