Free electronics advice and information
3.5 million visitors each month
Go Back   AVForums.com > Video Electronics > Projectors
Latest popular product pricesPowered by
Optoma HD20
Optoma HD200X
Sanyo PLV-Z700
Optoma ES522
Optoma HD20
Optoma HD200X
Sanyo PLV-Z700
Optoma ES522
Epson EH-TW2900
Acer X110
Optoma HD65
Benq MP727
Epson EH-TW3500
Toshiba TDP-S25U
 More...Prices updated March 21st at 10:30am and include delivery.
Old 03-06-2006, 8:30 PM   #1 (permalink)
Help: Projector auto shut down in several minutes
HI,
My Sanyo PLC-XU20 always shut down in 2-3 minutes after starting up. I have been trying to restart it for several days. But it still self-shut down. Anybody had the same experience before? The lamp is OK.
cheers
leonzwl is offline   Reply With Quote
Old 03-06-2006, 9:25 PM   #2 (permalink)
Oakleyspatz's Avatar
Thanks: Gave 33, Got 200
Originally Posted by leonzwl
HI,
cheers
Try resetting the firmware. Should explain how in the manual but you usually hold down a couple of buttons for a few seconds. Sound like the current one is corrupt. I can't see it overheating that quickly so I doubt if it is that and you say the lamp is ok (are you sure of this? If you bought it secondhand, it is possible to reset the hours even if the bulb has done many thousands)
Good luck!
Danny
Gear: Sanyo PLV-Z3 LCD Projector| Panoview Gray Wolf 92" screen|Denon AVR-2307| Sony Pascal Speakers|Velodyne Deco 600 watt Digital Subwoofer|Sky HD|Xbox 360 HD system |Toshiba HD-E1 HD DVD Player | Sony BDP-S1 Blu-Ray Player | Pioneer PDP-507XD 50" Plasma
Oakleyspatz is offline   Reply With Quote
Old 04-06-2006, 11:45 AM   #3 (permalink)
The Fatty's Avatar
Thanks: Gave 6, Got 5
does anyone knwo how to reset the epson tw10h firmware?
The Fatty is offline   Reply With Quote
Old 04-06-2006, 4:39 PM   #4 (permalink)
ashyx
Posts: n/a
How old is this PJ?
Seems to me it's the auto shutdown feature of the lamp. If it reaches a certain set amount of hours the lamp is deemed as past it's useable life and the PJ shuts it down to prevent damage. You can carry on using it at your own risk, but you need to reset the lamp life meter.
Old 04-06-2006, 9:04 PM   #5 (permalink)
HI,
cheers
It may well be overheating. Is the pj very close to a rear wall or does the filter need cleaning? These two things can lead to overheating and auto shutdown.
Old 04-06-2006, 10:19 PM   #6 (permalink)
Thanks: Gave 14, Got 31
It may sound stupid, but do you have a signal going to the projector when it shuts down? Many projectors have an auto shut down function when no signal has been detected for a few minutes.
ZippyCat is offline   Reply With Quote
auto, minutes, projector, shut
Copyright © 2000-2010 M2N E. & O. E.
