Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
InFocus Play Big X9
Acer X110
Optoma HD200X
Optoma HD20
Panasonic PT-AE3000
Optoma Pico
 More...Prices updated November 24th at 11:30pm and include delivery.
Old 01-06-2006, 8:26 PM   #1 (permalink)
Thanks: Gave 1, Got 10
Will HDMI or Component improve on S-VHS with Denon DVD and Hitachi PJ-TX200
I currently have a Denon 1920 DVD player connected to a Hitachi PJ-TX200 projector using a 10 metre S-VHS cable.
I am about to rewire everything as I've just bought a new amplifier (also a Denon) and I'm repositioning a few things in my room.
As I have the opportunity to lay new cables I'm interested to know if a HDMI or component video cable would make a significant difference over an S-VHS cable.
Component would be the most convenient (if an improvement over S-VHS) as the amp can do component video switching but not HDMI.
Any thought/advice gratefully received.
Mike
Sawdust is offline   Reply With Quote
Old 01-06-2006, 8:30 PM   #2 (permalink)
Oakleyspatz's Avatar
Thanks: Gave 33, Got 201
Originally Posted by Sawdust
Mike
Both will give a massive improvment over S-Video. HDMI should slightly have the edge on component but not by much.
Gear: Sanyo PLV-Z3 LCD Projector| Panoview Gray Wolf 92" screen|Denon AVR-2307| Sony Pascal Speakers|Velodyne Deco 600 watt Digital Subwoofer|Sky HD|Xbox 360 HD system |Toshiba HD-E1 HD DVD Player | Sony BDP-S1 Blu-Ray Player | Pioneer PDP-507XD 50" Plasma
Oakleyspatz is offline   Reply With Quote
Old 02-06-2006, 1:44 PM   #3 (permalink)
Thanks: Gave 3, Got 16
For small values of 'massive'.
I didn't notice a significant improvement going from s-video to component on my projector. I was expecting a bigger difference, but it was marginal at best.
wyrdness is offline   Reply With Quote
Old 02-06-2006, 2:33 PM   #4 (permalink)
Yes, that's kind of what I wondered.
Oakley, what would you describe as a 'massive' difference?
Mike
Old 02-06-2006, 6:29 PM   #5 (permalink)
Mike
Ok, 'massive' may have been a little over the top, but I find component produces sharper images with zero colour bleed and much reduced picture noise and grain compared with S-Video especially on longer cable runs. HDMI improves slightly on all the component improvements mentioned.
Change 'massive' to 'considerable' then shall we.
Old 02-06-2006, 7:31 PM   #6 (permalink)
Miniholic's Avatar
Thanks: Gave 516, Got 386
I'd go for massive difference personally.
I've taken a couple of screenshots to show the difference (zoomed in to show greter detail).
I'm using a Denon 3910 DVD Player and Panasonic AE500 Projector. Both pictures have just been cropped, no other processing has been done.
S-Video
HDMI (upscaled to 720p using the 3910)
Sony HW10, Denon 3910, 3806. Toshiba HD-EP30. Pioneer CLD-D925, TF100GB. Panasonic BD35, NS830 VCR.
Carada Criterion 92" screen. PS2. Wii. B&W 602.5, LCR60, 601s3, 600s3 & ASW675. Harmony 1000.
My DVD’s The Miniplex Skip to the end...
Miniholic is online now   Reply With Quote
Old 03-06-2006, 6:13 AM   #7 (permalink)
PJTX100's Avatar
Thanks: Gave 256, Got 280
For me there was a "noticable" difference from s-vid to component and a "slight" difference from component to DVI. Depending on the player, the "slight difference" could be either better or worse.
A man's life in these parts often depends on a mere scrap of information.
PJTX100 is offline   Reply With Quote
Old 03-06-2006, 10:07 AM   #8 (permalink)
What I forgot to mention yesterday, is that I did get a significant improvement in going from interlaced on s-video to progressive on component.
I suspect that's part of the reason that miniholics s-video vs hdmi pictures show such a difference. Miniholic - is your hdmi pic progressive and has it been upscaled?
Old 03-06-2006, 10:23 AM   #9 (permalink)
Miniholic's Avatar
The second pic is 720p, upscaled using my Denon 3910.
Old 03-06-2006, 10:30 AM   #10 (permalink)
Thanks: Gave 10, Got 13
Somethings very wrong somewhere if you don't see a big difference from s-video to component or HDMI.
Either your source is not very good in the first place or your display needs a good bit of tweaking.
You've only got to look at miniholics screenshots to see a massive hike in picture quality.
Sanyo Z3 projector, Playstation 3,Panasonic th37pa20 plasma, yamaha rxv440 receiver, Ruark Talisman Floorstanding fronts, Kef reference 100 centre,Mission M7DS Rears, Rel Quake Sub, One for all Kameleon Remote.
gingerone is offline   Reply With Quote
Old 04-06-2006, 1:17 PM   #11 (permalink)
Thanks for that Miniholic - I'll order a cable today !!
Thanks for everyone's replies, I'll let you know how I get on
Mike
Old 05-06-2006, 12:26 PM   #12 (permalink)
pure_geordie's Avatar
Thanks: Gave 14, Got 25
I would like to know how you get on too ...as I have the same Quandry!!!
I've heard that HDMI isn't good over long distances and also the cost of them are significantly more expensive...Me not sure what to do because would like to got digital using HDMI cable but analogue may kust do for me because you can use your amp for switching...
Good luck...does anybody know where you can get a cheap but good 10 metre HDMI lead anyways.....
Sorry for hijacking asking that Q but I'm sure you would like to know too
PS3 slim/PlayTV/PSP, Sony STR-DG820B, Tannoy HTS200, Mitsubishi HC5500 Projector, Sapphire 89" Electric Screen, Running 10 Metre Vivanco HDMI, Panny SCHT-900, 32" & 37" LG3000 LCD TV, Sky HD
pure_geordie is offline   Reply With Quote
Old 05-06-2006, 12:51 PM   #13 (permalink)
Conspicuous Member
Pecker's Avatar
Thanks: Gave 1,625, Got 1,156
From my personal experience, 25% of the difference between S-Video & Component will be the mothod used, 75% will be because the component feed is progressive rather than interlaced.
Steve W
Pecker is offline   Reply With Quote
Old 05-06-2006, 1:42 PM   #14 (permalink)
Component doesn't have to be sent progressively it can be sent interlaced yet it will still look better than S-Video IMO and if it is to a digital display such as an LCD, plasma or DLP then all images are shown progressively by the monitor no matter what method it is sent.
I think it is almost entirely due to the method of transfer.
First we have the composite connection which carries all video information along one cable and this leads to a degradation of all aspects of the signal. Then we have S-Video which splits the image into chrominance (colour) and luminance (brightness) which reduces this degradation but not entirely as the colours are still united instead of seperated. Then there is RGB scart which is a type of component video and splits the signal into the three primary colours (red,green & blue) + Luminance. RGB Scart is almost identicle to component video except it doesn't send a progressive signal, only interlaced. Then you have progressive component which sits at the top of the video connection tree. The colours are seperated from each other and sent progressively.
So there you go, on an ascending scale of quality, S-Video is second from bottom. It is good, but nowhere near as good as component.
component, denon, dvd, hdmi, hitachi, improve, pjtx200, svhs
