01-06-2006, 6:01 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 99, Got 4,294,967,295 | what is the difference between DLP and CRT.
Hi Guys, I am new to projectors infact I know nothing about projecotrs, I got decent sound system and Now i am after big picture like cinema. so what should I do, which one is better in picture quality crt or dlp, help me out guys please. thanks.
01-06-2006, 7:02 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 33, Got 201 | Quote: |
Originally Posted by Shin Akuma Hi Guys, I am new to projectors infact I know nothing about projecotrs, I got decent sound system and Now i am after big picture like cinema. so what should I do, which one is better in picture quality crt or dlp, help me out guys please. thanks. | CRT was for as long as you could remember, the king of projectors with regards to image quality. It produced stunning blacks and incredible contrast with smooth film-like images although CRT projectors were never that bright. CRT projectors do have a downside though, they are huge machines that need professional installation and once installed, cannot be moved without painstaking re-installation. The three colour tubes need to be aligned exactly to produce a clear sharp image.
DLP on the other hand is a digital, portable system that uses a chip that contains microscopic mirrors that pivot so they can either reflect light or turn it off. This light passes through a colour wheel which spins very quickly producing the full spectrum of colours.
Originally, DLP was far, far behind the quality of CRT and produced blacks which were, at best, dark grey and had very low contrast ratios.
Today however, DLP is fast approaching the quality of CRT but without the headache of a fixed professional installation that CRT demands.
A DLP or for that matter, an LCD projector can be set up and running in a matter of minutes and the latest models produce stunning High Def images for not much more than £1000.
CRT is a dying technology in my opinion and is unsuitable for most people's requirements in today's AV home. DLP and LCD are where most get their Home Cinema pleasures from so go audition one today!
__________________ Gear: Sanyo PLV-Z3 LCD Projector| Panoview Gray Wolf 92" screen|Denon AVR-2307| Sony Pascal Speakers|Velodyne Deco 600 watt Digital Subwoofer|Sky HD|Xbox 360 HD system |Toshiba HD-E1 HD DVD Player | Sony BDP-S1 Blu-Ray Player | Pioneer PDP-507XD 50" Plasma
01-06-2006, 7:11 PM
#3 (permalink)
| | Senior Member
sorry i should have asked lcd or dlp? what is difference in quality of picture and how much do they last .
01-06-2006, 7:13 PM
#4 (permalink)
| | New Member
Thanks: Gave 1, Got 0 | CRT or DLP
Well personal preference is DLP due to picture quality, brighness, contrast and from the LCD Based pj's I saw they were sorry to say pretty poor
If you are looking sub 2k themescene do one (7 oaks sound and vision) it is about £1700
and they did demo another one which was better and it was £1500 sorry cannot remember what make it was poss a runco
but both were good images and even dark scenes were good
regards
sean
Sennheiser Hd 650 Headphones,Graham Slee Solo Headphone Amp,Modified Teac VRDS25, Rotel RSP 1068, Rotel RDV 1060, Rotel RMB 1075, M&K S150 THX Speaker System, Fujitsu 50" 58 series (just got), Sim2 Domino projector and Owl Video Electric Tab Tensioned Screen
01-06-2006, 7:19 PM
#5 (permalink)
| | Senior Member
Originally Posted by Shin Akuma sorry i should have asked lcd or dlp? what is difference in quality of picture and how much do they last . | Ahhh...Now that is a different matter!
Basically,
DLP=Uses Mirrors, High Contrast, Good Blacks, low pixelation, visible 'rainbows' to some viewers
LCD=Uses an LCD Panel, usually lower black levels, higher pixelation, sharper images, good colours, possible verticle banding ( VB) problem on some models.
This is a great generalisation and today, the gap between the two technologies is very close indeed. LCD can now produce fantastic blacks, great contrast and low pixelation and DLP can now be bought in 3 chip designs which completely removes any chance of rainbows. I would not like to say one is better than the other any more and you really need to audition a few of each to see which you prefer. Let me know your budget and I'll recommend a few models as I am sure many others will too!
01-06-2006, 7:26 PM
#6 (permalink)
| | Senior Member
Thanks: Gave 99, Got 4,294,967,295 | Quote: |
Originally Posted by Oakleyspatz Ahhh...Now that is a different matter!
Basically,
This is a great generalisation and today, the gap between the two technologies is very close indeed. LCD can now produce fantastic blacks, great contrast and low pixelation and DLP can now be bought in 3 chip designs which completely removes any chance of rainbows. I would not like to say one is better than the other any more and you really need to audition a few of each to see which you prefer. Let me know your budget and I'll recommend a few models as I am sure many others will too! | under 2g's
01-06-2006, 8:37 PM
#8 (permalink)
| | Senior Member
Originally Posted by Oakleyspatz | thanks mate, how much does it cost get a decent screen.
02-06-2006, 7:01 AM
#9 (permalink)
| | Senior Member
Originally Posted by Shin Akuma thanks mate, how much does it cost get a decent screen. | A 16.9 pulldown widescreen starts from about £80 upwards. I'd spend about £100 for my first one. Take a look at this Infocus one for £99 See: http://www.hifibitz.co.uk/product.asp?id=4615
Or this Beamax one for £114.99 See: http://www.hifibitz.co.uk/product.asp?id=3187
The one I have is a high contrast grey screen which is £85 (+vat) but has a limited viewing angle which could be a problem for you. If you sit bang center in the middle of the image it is fine, but move to the sides and the brightness drops. If you can accomodate the high contrast grey screen, the reward is much increased blacks and improved contrast. See: http://shop.nexnix.co.uk/Greywolf_Pr...n_Screens.html
