Can Plv Z2 Do Anything Other Than 60hz
Old 07-04-2006, 7:57 PM   #1
BritanniaJaf's Avatar
8,640, Level: 22
Points: 8,640, Level: 22 Points: 8,640, Level: 22 Points: 8,640, Level: 22
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 39, Got 38
Bought top spin 2 and unbeliveably only plays on 60 hz, is there any way to get 60HZ or am i FUC***
Old 07-04-2006, 8:19 PM   #2
8,640, Level: 22
Activity: 3.4%
Mods Can You Modify Title To Say Plvz2 Anything Other Than 50hz
Old 07-04-2006, 8:48 PM   #3
Oakleyspatz's Avatar
6,040, Level: 18
Points: 6,040, Level: 18 Points: 6,040, Level: 18 Points: 6,040, Level: 18
Thanks: Gave 37, Got 234
I believe it can do anything from 50hz to 100hz . Use the auto function to search for the signal. If you still have no joy, you may need to treat the signal as a PC signal and activate the PC auto function in the menu. (see page 31 onwards in your owners manual)
Old 07-04-2006, 10:23 PM   #4
8,640, Level: 22
Activity: 3.4%
FANTASTIC Oakley thanks very much, will let you know how it goes
Old 07-04-2006, 10:30 PM   #5
8,640, Level: 22
Activity: 3.4%
Just checked oakley my plv z2, is on component for the 360, and the option for choosing between 480i and 720p is on auto so not really sure what else i can change
Old 07-04-2006, 10:57 PM   #6
6,040, Level: 18
Like I said, it may have to treat the incoming signal as a PC signal. You need to use a component input which is assigned to PC. The make sure the auto PC select function is activated.
Try connecting the X-Box but leave it switched off, turn on your pj and then turn on the X-Box. Hopefully it will register the connection and search for the correct sync to the signal.
Old 07-04-2006, 11:05 PM   #7
8,640, Level: 22
Activity: 3.4%
ah, right no probs, will give it a bash, cheers for your help m8, here's hoping
Old 08-04-2006, 10:44 AM   #8
8,640, Level: 22
Activity: 3.4%
Sorted, oakley all up and running, cheers for your help m8
Old 08-04-2006, 11:09 AM   #9
6,040, Level: 18
Great! What was the problem in the end?
Old 16-04-2006, 11:20 AM   #10
8,640, Level: 22
Activity: 3.4%
It was the 360, because i the cable on HD setting the 360 does not allow you to change the pal settings on that option, need to change the cable to normal TV output and low and behold the PAL settings change appears, what a carry on, cheers for all your help m8
Old 07-11-2009, 1:31 PM   #11
5,565, Level: 17
Points: 5,565, Level: 17 Points: 5,565, Level: 17 Points: 5,565, Level: 17
Thanks: Gave 1, Got 1
Re: Can Plv Z2 Do Anything Other Than 60hz
You say the PLV-Z2 can do 50hz to 100hz then do you know if it will work in 3d mode with shutterglasses like nvidia 3d vision? As far as I know to be able to do 3D it will have to be able to have a true input of 85hz, is this what the PLV-Z2 has?
Many thanks in advance
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
5 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 11th at 3:30am. Prices include delivery.
