Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD65
Benq W1000
Toshiba TDP-S25U
Sanyo PLV-Z700
Optoma HD200X
Optoma Pico
Epson EMP-TW700
Acer X110
Panasonic PT-AE3000
Optoma ES522
 More...Prices updated November 21st at 11:30pm and include delivery.
Old 16-03-2002, 3:49 PM   #1 (permalink)
stevenr
Posts: n/a
Question Ideal lumen rating
After reading many posts here and elsewhere I will make the following assumption. A projector with a lumen rating of more than 900-1000 will not be as ideal as a projector with say 600-900 lumens, for home cinema use. Is it because you will lose detail in dark scenes with a high lumen projector?.
I also think there is further investigation to be done regarding grey screens, has anyone tried painting plastic or other surfaces with icestorm paint?.
Old 17-03-2002, 9:16 PM   #2 (permalink)
Chris Frost's Avatar
Thanks: Gave 41, Got 94
It's true the home cinema projectors tend to be less bright than those used for presentations, but looking at one figure, like ANSI lumens, isn't the answer. There has to be a balance between brightness, contrast ratio, screen size, room lighting, screen surface etc.
An 800 ANSI projector with 200:1 contrast could look worse than something more powerful but with better contrast.
I know this sounds obvious, but you need to see and judge projectors for yourself before buying.
Regards
Chris Frost
Chris Frost is offline   Reply With Quote
ideal, lumen, rating
