Hello Oakleyspatz
You do need to put an over-rider or two on your 'Tip of the day'
01. Often DVR's produce a pretty soft image when outputting Component (YPbPr) video.
02. You always have to have the DVR switched On and some of the hard drive versions are mighty noisy.
A decent quality RGB2YUV converter may look costly but is worth while investigating if you want the cleanest signal to your projector.
Best regards
Joe
