got a reply from RAGEdemon, he's encouraging, especially seeing as how he's done it...haven't coaxed him to here, but when i've got something together to ask him, i'll get back to him with questions
just a quick
ish update (same as at "to all projector owners...")
well, i sent this to the maker hkje (ebay)...
hello...i have (with others) been researching leds to replace the uhp lamps in projectors...we require dimmable, mains powered led lamp clusters, if you're interested...the common factor is that the space in the lamp housing of basically all uhp lamped projectors is 45mm x 45mm x 45mm (square), and the brightness requirement is in a range from approx 500 to 5000 lumens...although this may be beyond the current capabilities of led technology, the closer you can get to this ideal, the more potential customers you will have...incidentally, the high lumen number i have stated is most likely only as a result of filters/polarizers fitted into projectors, which could be removed, giving (i estimate) a maximum requirement of 1500 lumens...this may appear to be a restricted market i am asking you to develop product for, but think of the general lighting market - the potential for sales of compact lamps this size is huge (desklamps etc) - i would be happy to answer any questions...regards, matt
...lets see if anything comes of it
i was writing about this lamp business elsewhere, and it occured to me upon reading about the mitsu pocket pj (
http://www.bigscreenforums.com/forum...572%26page%3D2 - 40 lumens output ! or possibly 120 lumens output - if 40 each of three leds) that the real problem here after the phoney lamp use bit, must be neutral filters and polarizers...if and when i get brave enough to do this thing (post warranty - still some months away) it would be wise to try with either no neutral filters/polarizers in place at all, or if adjustable, polarizers tuned down to minimum filtration
i'm going to contact luxeon/futurelectronics again with a similar message to the above
