To make a long story short I am a total noob about projectors and I need some help to see if buying a projector is a viable solution for me.
I am a real fan of BIG, I just can't get enough size....and when searching for a new TV to watch movies, xbox and stuff this has led me to take a look at projectors for their very good size/price ratio.
My problem is, my room is kind of small. It is about 2.5x2 meters. So The max distance I would be projecting from is about 2.4 meters. I read the recent tom's hardware round up and I noticed every projector has minimum and maximum throwing distances. for example the Hitachi one, had 96-158" throwing distance to project a 76" picture. Does the throwing distance within those 96-158" effect the quality in any way? Or is it just a customization of the Lens? Can I break these rules and project more than 76" in 96" throwing distance which is the minimum? and if so would there be any consequences to the image?
Should I search for a projector with low minimum distance, and are there any?
1 more question, about the lamp life. Most manufacturers say 3k hours, does this mean that the average lamp will burn in about 3k hours or that after 3k hours you will start having greatly reduced light? about how much do replacement lamps cost?
Thanks a lot in advance, I will be bugging you more after I understand more
