Cheapest place for a Panny AE700 0r AE900
Old 25-01-2006, 1:14 PM   #1
5,618, Level: 17
Points: 5,618, Level: 17 Points: 5,618, Level: 17 Points: 5,618, Level: 17
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 27, Got 22
As i said in an earlier thread i have £1100 to buy a new PJ which i have (with help off the forums) narrowed down too a AE700 or AE900
Im still unsure of the main differences between the 2 so i am just going for the cheapest one i can find
Its been years since i looked up buying a projector so can anyone help me with prices?
at Komplett the AE700 is £959.00 Inc. VAT
and at Pixmania the AE900 is £1 048.95 Inc. VAT
does anyone know anywhere cheaper?
Old 25-01-2006, 4:17 PM   #2
4,347, Level: 15
Points: 4,347, Level: 15 Points: 4,347, Level: 15 Points: 4,347, Level: 15
Think those are the cheapest I've seen - try http://www.pricerunner.co.uk if you haven't already. Komplett used to sell the AE700 for £933 a few weeks back
Old 25-01-2006, 4:56 PM   #3
3,942, Level: 14
Points: 3,942, Level: 14 Points: 3,942, Level: 14 Points: 3,942, Level: 14
Thanks: Gave 28, Got 5
7% discount
buy a vipix card for £14 from pixmania and you'll get another £70 ish off
Old 25-01-2006, 5:13 PM   #4
Fluffy-Bunny
Posts: n/a
Go for the AE900, ive seen it for £1025 I believe at PRC Direct...
Old 25-01-2006, 6:12 PM   #5
5,618, Level: 17
Activity: 0.7%
On the website it says
"7% immediate discount on a selection of marked items with the mention "7% discount" valid on www.PIXmania.com website."
i have emailed them and asked them if i am entitled to 7% off the AE900
Old 25-01-2006, 6:38 PM   #6
5,618, Level: 17
Activity: 0.7%
just found digital direct do it for £1020.75 with £14.99 for delivery
and Sound & Vision do it for £1035.74 inc Delivery
so Both £1035.74
Old 25-01-2006, 7:22 PM   #7
PeteIvy's Avatar
4,799, Level: 16
Points: 4,799, Level: 16 Points: 4,799, Level: 16 Points: 4,799, Level: 16
Thanks: Gave 44, Got 49
might be worth a mention that komplett are selling a b grade ae700 (probably a battered box. it states 0 hours usage on the bulb. might be worth sending then a mail!)
http://www.komplett.co.uk/k/ki.asp?sku=307691&cks=SER
£889.01
Old 25-01-2006, 7:49 PM   #8
4,814, Level: 16
Points: 4,814, Level: 16 Points: 4,814, Level: 16 Points: 4,814, Level: 16
Thanks: Gave 2, Got 4
I'm buying one of the AE900 projectors in the next few weeks, and I've seen some sites are selling for around the £1200/£1250 - some with "free" pixel check, and one with 3 year warranty.
Are these two options worth considering, or should I just go with the lowest price?
Old 27-01-2006, 1:33 PM   #9
5,618, Level: 17
Activity: 0.7%
Well a 3 year warrenty costs £179
so 1035 + 179 = 1214
So they work out near the same
http://www.prcdirect.co.uk/PRC/PRC.s...roduct/PTAE900
thats the cheapest with a 3 year warrenty i can find on the net, just make sure u select the warrenty though
Oh and if you want good service Domestic and General (which is the company used above anyway) are fantastic in the dealings i have had with them.
Old 27-01-2006, 1:36 PM   #10
5,618, Level: 17
Activity: 0.7%
oh just to add dont go with just the projector alone, a bulb costs £150-£250
and u will more than likely need a new one or maybe 2 within 3 years so u will be saving money in the long run, not to mention other faults that come with projectors
Old 27-01-2006, 1:57 PM   #11
8,522, Level: 22
Points: 8,522, Level: 22 Points: 8,522, Level: 22 Points: 8,522, Level: 22
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 181, Got 357
Bulbs are not usually covered in the extended warranties...but they last 2-3000 hours so to need 2 new bulbs in 3 years you would have to use it 6 hours a day everyday.
Old 27-01-2006, 3:57 PM   #12
5,618, Level: 17
Activity: 0.7%
i had 3 bulbs replaced in my AE100 in 4 years with D&G
so in my experience bulbs are included when parts and labour is stated
but maybe u should check beforehand just incase its changed
Old 27-01-2006, 5:51 PM   #13
8,522, Level: 22
Activity: 0.8%
Domestic And General don't list Panasonic Projectors on their website - is this something you need to ring about or have they stopped this service?
Old 28-01-2006, 10:08 AM   #14
Assured Advertiser
benji_m's Avatar
4,663, Level: 16
Points: 4,663, Level: 16 Points: 4,663, Level: 16 Points: 4,663, Level: 16
Thanks: Gave 8, Got 7
D & G don't seem to know what a projector is half the time!
And the bulb is most certainly not covered, we tried sourcing our warranties from them but gave up after they couldn't seem to get a straight answer or straight price.
HTH
Old 28-01-2006, 12:26 PM   #15
5,618, Level: 17
Activity: 0.7%
Well on 2 sites that sell the AE900 they have the option of choosing 3 or 5 years extended warrenty and its with D & G
so surely if u buy from a website thats already sorted it out you should have no problems
Benji i had my bulb replaced 2 or 3 times so mine certainly was covered
Scumball i rang them up about it yesterday they gave me a quote straight away. Plus they know i have a Projector already becuase they have just gave me a payout for my AE100 so if they didnt do warrentys on PJs they would have told me there and then.
Maybe i was lucky and found a loophole
Old 29-01-2006, 10:33 PM   #16
5,618, Level: 17
Activity: 0.7%
its dropped £2 at them shops now for some reason
its now £1,033.69
Old 31-01-2006, 1:37 PM   #17
5,618, Level: 17
Activity: 0.7%
Can anyone shed anylight on these price drops and increases?
I went to order my AE900 yesterday at £1033 but the cheque hadnt cleared
come to order today and its gone upto £1055
whats happining?
Old 01-02-2006, 4:11 PM   #18
5,618, Level: 17
Activity: 0.7%
HTH
I ordered my PJ today and they said on the phone if i took the extended warrenty it covers parts inc the bulb
Old 02-03-2006, 9:19 PM   #19
Quddy
Posts: n/a
I am a total novice when it comes to this stuff but recently decided to purchase a projector. Was pointed to these forums by a friend and have had a good read through the various stickys.
Anyway, decided on the Panasonic PT-AE900 and thought I'd let you know that Sound and Vision now have this for £990.00 inc. VAT and P&P which I think is great value. I ordered one, should be here on Monday!
Just have to find a decent screen now.
Old 03-03-2006, 1:46 AM   #20
calibos's Avatar
8,425, Level: 21
Points: 8,425, Level: 21 Points: 8,425, Level: 21 Points: 8,425, Level: 21
Thanks: Gave 18, Got 29
I guarantee you will be back posting in a few days...
OMG, WOW, Why did I wait so long to get a PJ, Best thing I ever bought in my Life etc etc.
I've owned PJ's since 2002 and put 3300 hours on my AE100, 9970 hours on my AE300 and 1450 hours on my AE900 and I still giggle everytime I put a new DVD on.
Your going to love it mate!
Old 03-03-2006, 12:21 PM   #21
6,724, Level: 19
Points: 6,724, Level: 19 Points: 6,724, Level: 19 Points: 6,724, Level: 19
Thanks: Gave 3, Got 1
Agreed, calibos. I bit the bullet when the AE700 came out and bought one unseen, and have never regretted it once. Even on blackout cloth with a black felt border, the picture is stunning.
Old 03-03-2006, 8:58 PM   #22
Quddy
Posts: n/a
Cool, can't wait!
Always wanted one but could never afford one, still can't, but did bucket loads of overtime at work the last couple of months so I thought I'd treat myself.
Was thinking about buying a cheaper 26" HD LCD tv but as there is absolutely nothing on the telly in HD at the moment and not likely to be in the immediate future I decided to buy the projector for DVDs and gaming and keep the current crt for tv.
Still looking for an affordable screen though. I think i'll wait for the projector to arrive and see what size screen I require.
Powered by
 Latest popular product prices
Aiptek PocketCinema T15
4 prices from
 £90.53 Click to show/hide the offers
Optoma Pico PK120
3 prices from
 £134.99 Click to show/hide the offers
Acer C110
3 prices from
 £148.80 Click to show/hide the offers
Dukane ImagePro 8758
1 price
 £192.98 Click to show/hide the offers
Optoma Pico PK301
4 prices from
 £248.97 Click to show/hide the offers
Optoma DS211
6 prices from
 £228.96 Click to show/hide the offers
Acer X110P
5 prices from
 £238.75 Click to show/hide the offers
Benq MS500
5 prices from
 £238.00 Click to show/hide the offers
 Updated February 11th at 1:30am. Prices include delivery.
