I had been resisting getting any further involved in the hysteria about projectors and lamp life and whether they are suitable as substitutes for televisions etc. but can't resist asking about this.....
As far as I'm aware (looking at this from the point of view of a relatively well-informed, but not technically expert, general enthusiast) there was never any suggestion that my Sanyo projector was not suited to be used in more or less the same way as a conventional television.
perfectly normal for a machine advertised as a television substitute
Bert,
You will know that I'm not being picky or taking a pop at you just for the sake of it, but the fact that something doesn't say it's not fit for a particular purpose doesn't make it suitable for that purpose... for instance I'd say at a guess that the literature doesn't explain that projectors shouldn't be attached to the end of a string and be used as kites, but that doesn't mean that theyre suitable for use as kites.... extreme example for illustration.....
I haven't seen projectors advertised as television substitutes and I'd be interested in seeing any you could point me at.....
With regard to other posts and the topic in general, as far as I can remember on the forums there has been a fairly standard line of advice to the effect that projectors are not suitable for use as a substitute for a television (or plasma/whatever).
Claims about 11 year old cars etc don't impress me - when a projector is turned on it's effectively performing at the limit of it's capabilities constantly. Try driving you car at maximum revs 10 hours a day for 11 years and see if it's still like new..... ever wonder why the police change their cars every couple of years ? It's because they're pretty worn out from constant use 24/7.
In the spirit of recent threads on this subject, I was considering starting a new thread with the title "
Shock! Horror! Your Projector Won't Last Forever !", but will spare the forum population's feelings.
Just for the record, guys and gals,
This is a projector:
and this is a television:
They're not the same.
Sean.
