Go Back   AVForums.com > Video Electronics > Projectors
Today's price checkPowered by
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
Optoma HD65
Toshiba TDP-S25U
Sanyo PLV-Z700
Benq W1000
InFocus Play Big X9
Acer X110
Optoma HD200X
Optoma HD20
Optoma HD700X
Panasonic PT-AE3000
 More...Prices updated November 24th at 9:30pm and include delivery.
Old 19-12-2005, 12:05 PM   #1 (permalink)
Thanks: Gave 104, Got 153
AE900 Standby Noise
When I got my AE300 it used to make a very low volume high pitched noise when left it on standby and could only get rid of it by turning it off. After time I either got used to it or it stopped.
I've just got an AE900 and it's doing the same, it's mounted about 5 foot above my head. I can't hear it straight away but if can't sleep it become really obvious and can only stop it by turning the power off.
Has any one else experienced this ?
Can it be stopped other than turning the power off ?
T800 is offline   Reply With Quote
Old 19-12-2005, 12:07 PM   #2 (permalink)
PJTX100's Avatar
Thanks: Gave 256, Got 280
I would suggest it's good practice to turn the power off anyway. Certainly with the 700 there were many reports that it helped to reduce VB.
A man's life in these parts often depends on a mere scrap of information.
PJTX100 is offline   Reply With Quote
Old 19-12-2005, 12:28 PM   #3 (permalink)
Will it make much difference if I turn it off via the switch or at the plug (it's easier at the plug) ?
Old 19-12-2005, 12:37 PM   #4 (permalink)
PJTX100's Avatar
Would've thought the plug should be fine.
ae900, noise, standby
