| homemade projector mount question
I am a big fan of custom building pieces for my home theater such as mounts, tables, and what not. My question is if vertical lens shift will keep me from having to build a projector mount that has adjustment points.
Basically, i want to build a fixed mount that allows no pitch or yaw for the projector, mount it on the wall at the proper heighth, and use the lens shift to make the minute adjustments to project it within my screen's limits. Am I right in thinking this or should I build my mount so that it came aim the projector within the bounds of the screen?
Not having to do anything but screw the projector to the mount would be a much simpler design than having to build pivot points.
